diff and transfer case
Old Oct 9, 2007 | 09:06 AM
3500eh's Avatar
wanting to change rear and front diff , as well as transfer case oil out tomorrow. sounds easy enough. just take cover off and let her drain. is there some sort of gasket to watch out for?
not to sure how to do transfer case or what is best to use for it. some sort of synthetic ? how much and how do i drain transfer case?
thanks
Old Oct 9, 2007 | 10:31 AM
BLUEBURNER's Avatar
the transfer case takes atf4 i believe
Old Oct 9, 2007 | 01:01 PM
ShaneCTD600's Avatar
^^^ correct, just did everything you mentioned. ATF in the t-case. I put in 75W-110 in the diffs.
T-case, remove the skid plate. remove the drain screw, remove fill screw, replace drain screw, fill to height of fill screw, replace fill screw, replace skid plate. 20 min job
Diff's, remove cover and let drain, clean off magnet on fill screw, reuse same gasket and replace cover. Add fluid to fill screw level. replace fill screw
wyododge
Aug 18, 2011 07:48 AM
Marty86
May 2, 2009 07:58 PM
SBRW
Jan 11, 2008 09:09 AM
SBRW
Jan 11, 2008 07:56 AM
