Diesel Fumes
Old 11-28-2006, 10:48 PM
RZinKY's Avatar
Diesel Fumes
I'm getting diesel fumes in the cab. I have not seen or heard and exhaulst leaks but have not crawled under the truck due to back fusion 5 weak ago. i assume it would have to be exhaulst or fuel leak.
Old 11-28-2006, 11:21 PM
kawi600's Avatar
Probably one of the hoses near the injection pump has dried out and cracked. Id check those, especially the return hose way in back right next to the block. you can unbolt the brake master and pivot it out of the way, and remove the fuel filter to get good access to that area.
Old 11-29-2006, 03:01 AM
plow's Avatar
check the weather stripping that seals the hood to the cowl.
Old 12-02-2006, 03:20 PM
js
js's Avatar
if you are talking about exhaust fumes I get that now and then. I think on mine it comes in when the heater or a/c are drawing fresh air and the wind is blowing just right. only ever had this when stopped at lights or driving really slow in rush hour.
Old 12-02-2006, 06:30 PM
infidel's Avatar
What you describe is exactly what happens when the seal inbetween the rear of the hood and windshield falls off.
Old 12-05-2006, 06:49 PM
js
js's Avatar
nope the seal on my truck is in place. glued it back on 2 years ago after it came loose.
Old 12-05-2006, 07:15 PM
Forrest Nearing's Avatar
while driving or while parked sitting still?
while driving is bad!
while stationary is unfortunately normal unless you've got the AC on max
Old 12-08-2006, 07:42 PM
BigBRUNO4's Avatar
Yep me too. I thought something was leaking in my rig but I'm glad to hear this is normal at idle or when just starting up.
Oh that sweeeeet smell of diesel smoke
Old 12-08-2006, 11:05 PM
lol, it was really pumping tonight while I was sitting at a light... I know its not good for you, but I was taking hits off the dash vents
Old 12-09-2006, 01:42 AM
CumminsRedneck's Avatar
you people sound like me....i always shut the garage door before i turn off my truck just so i can smell the diesel as i walk behind it to go in the house....i LOVE diesel fumes
loid mongol
11-04-2005 04:19 PM
routerguy99
18
06-30-2003 02:23 PM
dansdad
06-19-2003 10:45 PM
Shovelhead
06-18-2003 07:51 AM
KRN
06-01-2003 06:54 AM
Quick Reply: Diesel Fumes
