View Poll Results: How did your VP44 die?
STOCK LP, UNKNOWN FUEL PSI
33.02%
STOCK LP, > 5 PSI
15.09%
CARTER/WALBRO LP, > 8 PSI
0.94%
CARTER/WALBRO LP + BIG LINE KIT, > 8 PSI
0.94%
FASS, RASP 12-15 PSI
0.94%
HAS NOT DIED
50.94%
Multiple Choice Poll. Voters: 106. You may not vote on this poll
Old 03-30-2007, 03:43 PM
smokindog's Avatar
Alright fellas, just a simple poll. No comments necessary.
Old 03-30-2007, 03:48 PM
keithw1975's Avatar
Mine was running fine then one night after work it cut out a few times on the way home. Parked it at home for a couple of hours then when I tried to leave it would start then after about a minute it would idle rough and die. Did this many times until I finally gave up and realized it was the VP.
Old 03-30-2007, 05:25 PM
C&C Milo's Avatar
I'm not sure how to define my failure. I have had 2 VP44's replaced under warranty. One after about 5000 miles and the second at 40,000 miles. Both times the truck ran perfectly but the check engine light came on. I took it to the dealer and he replaced the VP44. The LP has never been replaced.
Old 03-30-2007, 07:44 PM
Silverfox99's Avatar
my truck was running prime and one day i matted it up to about 70 let of and seen all the gauges die.........wasnt cool....bruised my wallet to
Old 03-30-2007, 07:59 PM
swmnkdinthervr's Avatar
Mine died a slow death...had a nasty miss at idle, nothing helped, started surging a little at WOT, began to blow white smoke and surge bad under moderate to hard acceleration and a significant loss of power (lift pump was replaced a couple of months before the failure)...never threw a code
Old 03-30-2007, 08:52 PM
badme's Avatar
Mine had 16lbs or preasure, but the fuel module in the tank failed and it was 16lbs of air no fuel.
Old 03-30-2007, 09:15 PM
merrillr4's Avatar
I started to get the dead pedal. The dealer replaced the VP44 and did the intank pump. Then I deceided it was time to get gauges. When I first put them in, it read 6 psi at idle and 1-2 on the highway. So I bought bigger fuel lines and a Holley Blue. Now I have 25psi at idle and 16psi at WOT.
Old 03-30-2007, 11:40 PM
AllanP's Avatar
Mine was running fine. I was towing and pulled in for fuel. Truck would not start back up. I had no signs whatsoever that it was going out. This was at 6 years and 144k miles.
Old 03-31-2007, 08:30 AM
Administrator / Scooter Bum
Shovelhead's Avatar
Monitored Fuel Pressure with a full time gauge since she had 1,000 miles on her.
NEVER under 5 psi while running.
Edge Comp for ~ 4 years. (No pump wire)
Hooked up pump wire. Ran it for ~ 8 months at all levels.
Just died like I'd turned the key off without warning, or a single hiccup while running @ 2,000 rpm down the road on a warm December afternoon.
approx 83,000 miles
IIHRVP installed in it's place.
All good now.
Old 03-31-2007, 05:35 PM
hillbillymudrun's Avatar
181264 miles on the stock vp-44 maybe i am just lucky
Old 03-31-2007, 06:18 PM
Valv's Avatar
Not really, I had 253,000 on my '99, sold the truck last year and it's still running great.
Old 03-31-2007, 06:54 PM
MARKY MARK's Avatar
Mine died 15 minutes after I installed the Edge Comp.
Old 03-31-2007, 07:00 PM
acook's Avatar
Helped my friend out a few days ago, his FASS system died out on him.
Old 03-31-2007, 07:32 PM
I hope that mine lasts that long i have had my edge juice w/att with the wire tapped for 50000 and she is still holding up
Old 03-31-2007, 08:14 PM
bob ram's Avatar
Rough Idle
Code
White Smoke
Dead Petal
$ 1069 2 1/2 Hour
Quick Reply: How did your VP44 die?
