Did I get shafted on a clutch?
Old 01-10-2008, 05:49 PM
fordkiller43's Avatar
I bought a Con O clutch off of a guy on craigs list in Houston. We measured the disc and its only measuring stock at 12.25? From what Ive read on sites and other threads the Con O upgrades to a 13 inch disc. The clutch also has LUK stamped on it? Can someone gimme some insight here? Thanks a bunch y'all!
Old 01-10-2008, 06:00 PM
9 sec camaro's Avatar
I bought two of them for my 5spd there were two sizes first time I had the smaller one wich does not require a fly wheel exchange or some one to drill and tap the holes in the old fly wheel the 2nd one was the larger and both of them were luk parts.
Old 01-10-2008, 06:20 PM
P.J
P.J's Avatar
Sounds like you got a LUK.
If it were a South Bend it would have numbers engraved into it.
If you do find some numbers on it, call Peter at South Bend to see if he can decipher what you got.
How much did you give for it?
Old 01-10-2008, 06:21 PM
Thanks a lot man for the input. I have seen so many stories Im just tryin to figure out whats really goin on.
Old 01-10-2008, 07:19 PM
dieselman2300's Avatar
I'm pretty sure SBC uses LUK parts and just put thier own pads on them.
Old 01-10-2008, 07:27 PM
I bought it, slave cylinder, bell housing, pedal, wiring harness for 600 bucks. I needed all of this because I am doing a auto to manual swap this spring. Thanks for the input P.J.
Old 01-10-2008, 07:29 PM
KMKDiesel's Avatar
If new thats not to bad
Old 01-10-2008, 07:33 PM
Its got a lot of pad left on it. He said it was used for 5,000 miles and then was taken out due to sellin his old truck. He was gonna put it in his 98 but got a dual disc instead. I will check into them stamped numbers tho. Y'all have helped alot! Thanks!
Old 01-10-2008, 07:57 PM
I dont remember ANY stamped numbers on my Dual Disc from SBC.
Just call Peter in the morning and see what he says. I usually call at night and leave a message for him and it seems he does his call backs before they open.
Old 01-10-2008, 08:00 PM
dzlfarmboy's Avatar
The south bend clutches will have Luk stamped on them in the steel center section. Ever south bend i've put in has had that.
Old 01-10-2008, 08:02 PM
Yep, just like I said in my previous post. SBC uses LUK hard parts and puts thier own pads on them.
Haisley uses McLeod hard parts and EEP uses Mitchell hard parts.
Old 01-10-2008, 11:40 PM
1stGen545's Avatar
My MU 13-1.25 Con FE didn't have Luk on it and neither did the one i put in tonight in my 1st gen MU 13-1.25 Con FE. I think were fine Jeremy. When I'm done with my NV4500 swap ( for the 2nd timepulled the old one out to do the Allison ) and rebuild the motor in my 96' I hope we can start on yours. Are you still coming over tomorrow?
jacobrw1983
01-17-2011 12:11 PM
Swamp_Donkey
ABDTR #5
06-26-2010 02:21 PM
rogers259
03-28-2009 12:08 PM
Mike D
05-21-2006 04:47 PM
Quick Reply: Did I get shafted on a clutch?
