diagnostic code
Old Mar 9, 2005 | 09:48 PM
hmiller's Avatar
diagnostic code
Anyone have any advice on 99 dodge diesel diagnostic code 0211. This code reads "contact chrysler" I can't find anywhere on internet. Don't know if I should continue driving or if truck should go in ASAP. I was made aware due to orange check engine light coming on inconsistantly.
Old Mar 9, 2005 | 09:52 PM
phox_mulder's Avatar
Did a quick search and couldn't find anything on it either.
The 0200 range of codes is mainly Injection pump, Injector or Turbo problems.
Strange how all the online sources left that one out.
phox
Old Mar 9, 2005 | 10:36 PM
BIGBADBOB's Avatar
Did an extensive search. Could only come up with "injector #11 failure" Will be interesed in what you get from dodge??
Bob
Old Mar 9, 2005 | 10:57 PM
roysleight's Avatar
That's what I get........."Injector circuit - cylinder 11". Whatever that means! Hope it helps.
Old Mar 9, 2005 | 10:58 PM
hmiller's Avatar
Any OBD code I have found shows that 0211 is a generic code for "injector circuit malfunction - cylinder 11" Obviously this is an issue with a 6 cylinder engine???
Old Mar 10, 2005 | 11:18 AM
tool's Avatar
Yep, I checked out my OBDII stuff and I also got injector circuit/open circuit
Old Mar 12, 2005 | 10:44 PM
millertime1's Avatar
omb codes???
If a code shows on my CTD, how do I know what the code means ? Is there a list available?
Thanks for the informative forum for a newbie diesel owner
Old Mar 12, 2005 | 10:59 PM
Haulin_in_Dixie's Avatar
I would erase it and see if it resets. I have one that comes up occasionally. When I turn the key on for some reason not running the engine like when installing and testing the blower motor, it sets I think 0237, low boost pressure voltage. I erase it and it does not come back.
Old Oct 11, 2006 | 10:05 PM
malukk's Avatar
Does anyone know what the code 2509 means? Or even where you go to check what the codes mean, or where to find a code list could also be very helpful.
Old Oct 11, 2006 | 11:20 PM
crobtex's Avatar
For code referance look here and here .
Derek Edgar
Jul 4, 2010 12:42 AM
kingofdodge7131
Apr 29, 2005 01:20 AM
Tazman
Oct 1, 2004 09:28 PM
SoCal-305
17
Aug 8, 2004 11:19 AM
Chillimau
Jul 10, 2003 09:17 AM
