Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
dewatering?
Old 02-27-2011, 11:41 AM
rockwithjason's Avatar
dewatering?
why is dewatering so important in the biodiesel process? there seems to be some water content in all the dino fuel so why all the emphasis?
Old 02-28-2011, 10:02 AM
kawi600's Avatar
dewatering is important in both. Its why we run water-block filters and water-in-fuel indicators. It can boil and impinge under pressure and rot metal parts.
I tried doing the heat and spray method but it left a lot of water behind. I found the best way to remove water was to heat the fuel to 180F in a water heater tank and draw a vacuum on it until it stopped bubbling.
I need to make a condenser of some kind the next time I do it, Im wrecking my vacuum pump with the steam.
Old 03-02-2011, 09:57 AM
irocpractice's Avatar
Why not take the water vapors off the top of the still and run them thru a condensing coil and then a rag separator with the vacuum pump on a bypass?
Just sayn
Old 03-03-2011, 03:23 PM
b4black's Avatar
Biodiesel can hold a lot more dissolved water than ULSD. And it doesn't shed the free water as well (more likely to make emulsions).
biododge1
03-05-2008 08:03 PM
Quick Reply: dewatering?
