Delivery Valve Washer Price
Old 11-12-2003, 02:05 PM
berner's Avatar
The useless Cummins dealer in town doesn't stock delivery valve washers. I phoned the dealer, they want $25.50 each. Is this what they're worth??
Old 11-12-2003, 02:24 PM
berner's Avatar
Re:Delivery Valve Washer Price
I just got quoted $2.42 ea from a diesel shop in town. Some days.......
Old 11-12-2003, 04:57 PM
Jim Fulmer's Avatar
$2-3 dollars a piece is about right.
Jim
Old 11-12-2003, 06:37 PM
boughtadodge's Avatar
I checked with the dealer and I was quoted around 15.00. I was working on setting the timing on a 96 and I pulled the number one delivery valve and there was no washer so I figured that someone forgot to install one so I checked with the dealer and was quoted that price then I pulled the number two delivery valve and it also did not have one either so I left it as it was. Does anyone know why there was none in this 96 with the 215 motor???? ??? ??? ??? ???
Old 11-12-2003, 08:49 PM
Jim Fulmer's Avatar
There wasn't any in my 98 pump either, I don't know for sure but I think there in the 160 pump trucks.....94'/95'.
Jim
Old 11-13-2003, 07:31 AM
I was thinking the same thing cause my 160 pump had them also. Do you think that removeing them on a 160 would help the performance seems to me like it would give more lift??
Old 11-13-2003, 08:24 AM
berner's Avatar
If there's none in my 180 pump, do I still torque the valve in using the 2 step method, 29 ft-lbs and then 85 ft-lbs in one motion?
Old 11-13-2003, 09:19 AM
MnTom's Avatar
There was none on my 180 pump either. If you don't have them when you stat the job you don't need them after.
Tom
Old 11-14-2003, 12:15 AM
tmiller24's Avatar
Inquiring minds need to know, can we leave them out of the 160 pumps?
Old 11-14-2003, 09:15 AM
DTR Advertiser
Don M's Avatar
Make sure the washers go back in if the pump had them in the fist place.
Any change in the height of the DV holder will lower or raise the spring rate of the DV spring = not good.
Put 'em back in on removal.
Don~
bob95065
02-27-2009 11:32 PM
9512vCTD
09-09-2006 04:30 PM
turbo6justin
04-22-2006 07:17 PM
Crimedog
04-09-2004 04:08 PM
Swamp_Donkey
05-14-2003 09:31 AM
Quick Reply: Delivery Valve Washer Price
