deep dish trans pan....
Old Dec 30, 2007 | 12:10 AM
dodgethis91cmns's Avatar
anybody besides ATS and maghytech make deep dish trans pans. i like them alot and want one but they are so darn expensive. is it true to that they save ur trans holding the extra fluid?
Old Dec 30, 2007 | 06:33 AM
KRB's Avatar
KRB
Mag-Hytec is supposedly the tops. PML is a little cheaper (Geno's, http://www.genosgarage.com/products.asp?dept=167). Summit (http://store.summitracing.com/egnsea...=KeywordSearch) has several that are a little cheaper and still supposedly good quality (you have a drain and can add a temp sensor etc).
When I was trying to lower my tranny temps it seemed that from reading the threads the pans only make a slight temp difference. The main plus was extra fluid that helped tranny life appearantly.
Old Dec 30, 2007 | 08:54 AM
powerrammaster's Avatar
The Mag is built real heavy and that also helps the structural integrity of the trans case. How important that is I don't know, but I was told that fact yesterday.
Old Dec 30, 2007 | 10:56 AM
flashgordon's Avatar
Ummm, wellllll, OK, I will buy that!
I would think that the HD casting would also be for that rock that got flung at yeah, by the truck in front of you(travaling 60+mph) or the bolder that you said, O SHET,as you slide over it, play off road!
Flash.
Old Dec 30, 2007 | 11:37 AM
BC847's Avatar
1st Generation Admin
I run this one from B&M http://store.summitracing.com/partde...5&autoview=sku
It had a drain and is easily tapped for a trans temp sensor. It's a quality build for the money.
EverydayDiesel
Nov 11, 2007 09:33 AM
chumstone
Feb 28, 2007 10:28 AM
KRB
Jan 28, 2007 04:54 AM
MrKen
Nov 23, 2006 03:19 PM
BigBlue
Sep 30, 2005 08:27 AM
