Decoding a VIN for options?
Old 11-05-2011, 08:43 PM
EricArrow's Avatar
Hi folks...can anyone here decode a vin for options? I just bought a 04.5 and was trying to find out what all the equipment is. Thanks
Old 11-05-2011, 11:19 PM
torquefan's Avatar
There's not much you can decipher from the actual serial number besides model year, assembly plant, and engine. What you need to do is send an email to the Dodge website and have them send you a build sheet. There is a thread on that here somewhere currently with the info on who exactly to ask. I'll see if I can dig it up.
Here's the thread:
https://www.dieseltruckresource.com/...d.php?t=296523
Old 11-06-2011, 12:39 AM
EricArrow's Avatar
Thanks....I just tried the link...
Old 11-06-2011, 11:30 AM
torquefan's Avatar
You're welcome.
Old 11-06-2011, 06:23 PM
EricArrow's Avatar
Dear Eric:
Thank you for contacting the Ram Customer Assistance Center regarding
your build sheet request.
We are pleased to provide vehicle build information per your request for
your 2004 Ram 2500.
According to our records, your vehicle was equipped from the factory
with the following:
VIN: 3D7KU28CX4G215206
Vehicle Description: DODGE RAM 2500 QUAD CAB PICKUP
Model Year: 2004
Body Model: DR 7 H 41
Sales Code Description
*V9 Cloth 40/20/40 Bench Seat
-DV Dark Slate Gray
ADA Light Group
AHC Trailer Tow Group
AHD Heavy Duty Snow Plow Prep Group
APDA Lower Two Tone Paint
A76P 5.9L TD Eng(ETH)/4Spd A/T 48RE (DG8)
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BRTS Anti-Lock 4-Wheel Disc Brakes
CBEP 40/20/40 Split Bench Seat
CFMP Rear Folding Seat
CGDS Front Height Adjust Shoulder Belts
CG1S Next Gen Multistage Front Air Bags**
CKES Front Seat Area Carpet
CLAS Front Floor Mats
CSPS Passenger Assist Handle
CUES Rear Underseat Compartment Storage
CUSS Overhead Console w/Trip Computer
DGBS All 4-Speed Automatic Transmissions
DG8 4-Spd. Automatic 48RE Transmission
DHAP Lock-Up Torque Converter
DH1S Man Shift-on-the-Fly Transfer Case
DJQS 5,200# Front Axle
DMF 4.10 Rear Axle Ratio
DRQP 11.50 Rear Axle
DSA Anti-Spin Differential Rear Axle
ETH 5.9L I6 HO Cummins TD Engine
GACS Tinted Glass Windows
GFD Rear Sliding Window
GNCP Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GNMS Passenger Side Sun Visor w/Mirror
GPG Power Black Trailer Tow Mirrors
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
K1XP STRIPE/BADGE/MOLDING/COLOR
K17 STRIPE/BADGE/MOLDING
LBCS Glove Box Lamp
LBDP Ash Tray Lamp
LCLP Front Dome w/On/Off Switch Lamp
LDAP Underhood Lamp
LMAS Halogen Headlamps
LNJ Fog Lamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MFDS Bright Grille
MTDS SLT Badge
MURS Dodge Badge
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCP Front Bumper Sight Shields
NAA Federal Emissions
NFUS 34 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMS Speed Control
NMCS Heavy Duty Engine Cooling
NZCP Current Generation Eng Controller
PW7A Bright White Clear Coat
QS2A Bright Silver Metallic Clear Coat
RAAC All Radio Equipped Vehicles
RBKS AM/FM Compact Disc Radio w/Chgr Ctrl
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
SBES Power Steering
SCFS 4-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TT5 LT265/70R17E OWL On/Off Rd Tires
TZGP BF Goodrich Brand Tires
WF1S 17" Steel Spare Wheel
WGSS 17X8.0 Steel Chrome Clad Wheels
WLYC All Steel Wheels
WMJP Center Hub
XBSS Pickup Box
XCKP Cummins Diesel 800 lb.ft. Torque
XEFP Transfer Case Skid Plate Shield
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XJL Front Hood Protection Shield
XME Under Rail Box Bedliner
YAAS Build To U.S. Mkt. Specifications
Our records indicate that the following recall campaigns have not been
performed by an authorized dealer:
E17 OUT-OF-PARK ALARM SYSTEM
H46 STEERING LINKAGE
We suggest that you contact your local authorized Chrysler, Dodge, Jeep�
or Ram dealer to make arrangements for an inspection and, if necessary,
corrective action at no charge to you.
Please take a copy of this message with you at the time of service to
aid the process. Although not required, it is recommended to bring a
copy of the recall notification with you to your dealer's service
department when you bring your vehicle in for this service.
If you wish to obtain further information, please contact the Chrysler
Group Recall Assistance Center at 1-800-853-1403.
Thanks again...they got back very quickly.
Old 11-09-2011, 10:42 PM
gsbrockman's Avatar
Old 11-10-2011, 05:00 PM
DTR Detective
steelblitzkrieg's Avatar
Originally Posted by gsbrockman
Times 2
Old 11-10-2011, 07:57 PM
EricArrow's Avatar
I think they should have put 610ft lbs correct?
JKM
47
10-21-2005 05:37 PM
Jim Swantko
02-05-2005 09:04 AM
Steve10
02-03-2004 04:33 PM
1320
05-04-2003 10:18 AM
Quick Reply: Decoding a VIN for options?
