Decoding
Old May 18, 2008 | 11:50 AM
Featherman's Avatar
Decoding
How do I determine what the original color scheme of my truck was when it left the factory? I cannot locate the data plate; would decoding the VIN assist in this.
Old May 18, 2008 | 12:49 PM
Dean Snow's Avatar
Is the data plate under the hood on gone or worn away? I think maybe if you would call the dodge dealership with you VIN number they could help you out.
Old May 18, 2008 | 05:44 PM
powerrammaster's Avatar
There is a stamped plate of tin under the cowl vent grate on the passenger side riveted to the cab with 4 rosettes. It has all the codes including primary and secondary paints(if applicable). A dealer or usually a paint supply store will be able to decode this for you. It will be a little bigger than a business card and have a ton of numerical/alphabetical codes stamped into it.
Old May 18, 2008 | 07:55 PM
Featherman's Avatar
found it
Thanks guys..................now I have to take it in and decode. My manual does not decode paint schemes.
75bronco
Feb 5, 2007 09:06 PM
JKM
47
Oct 21, 2005 05:37 PM
Jim Swantko
Feb 5, 2005 09:04 AM
Steve10
Feb 3, 2004 04:33 PM
1320
May 4, 2003 10:18 AM
