Debadged and still have the outline
Old 10-08-2008, 10:00 PM
oleblue's Avatar
Well I debadged my truck with the exception of the small cummins on the front fender. On the doors you can see where the ram 2500 was. Is there some type of rubbing compound or anything that I can make this blend in with? Its not terrible but it is noticable in the right light conditions.
Old 10-09-2008, 04:54 AM
sabersix's Avatar
I used the Mequiar's ScratchX on my 2007. Like you I could see a ghost of an outline at the right angle in the right light. It seemed to help.
In your case, I'd be concerned that the paint had faded around the badges since your truck is older. If so, you may never get it to blend totally.
Old 10-09-2008, 06:29 AM
Administrator/Jarhead
madhat's Avatar
I agree with the paint fading.
Try a Mr Clean magic eraser, other than that, you might have to try a very light rubbing compound, but I think that the paints faded.
Old 10-09-2008, 07:22 AM
Fog Runner's Avatar
If it is light where you can only see it in certain light conditions, you should be able to get it to blend, but you may not be able to to it by hand. If you get a good polish and a orbital you will be able to make it blend. Not a cheap orbital either, it would have to be one that can turn up some rpm's. I made mine vanish on my black truck with the right stuff. If it isn't bad you may be able to get away with a hand polish like mentioned above. The only reason that I had all of the stuff is because I do detailing on the side. If you don't have the right stuff, it may be cheaper just to find someone to do it for you, but you need to find someone whe will do it right. If you would like any details, just let me know.
Old 10-09-2008, 07:57 AM
oleblue's Avatar
I'll try the meguiars and the mr clean magic eraser and see what happens. If not, I may just take it to a shop that knows what they are doing and see if they can buff it out. I cant see it costing too much for such a small area.
Old 10-09-2008, 09:06 AM
tcr
tcr's Avatar
x2 on the Meguiars scratch remover! That is GOOD STUFF! and it acts as a wax too.
Old 10-09-2008, 09:54 AM
jusbecuz's Avatar
I just did my 03 a few weeks ago and had the same problem. I also used the Meguiars Scratch X by hand and it worked flawlessly. It took several applications, but now the shadow is gone from any angle and in any light. I applied a few coats of the wax that has the color in it, and then waxed the whole truck with carnuba, and you would never know they were there.
Old 10-09-2008, 10:04 AM
Patriot2500's Avatar
I vote for the Meguiar's stuff also.
Old 10-09-2008, 11:02 AM
EDR
EDR's Avatar
I would be cautious about using a Mr. Clean magic eraser. They work great on certain things, but I think if you read the packaging they come in, they caution against using it on polished surfaces as it may dull the finish.
I've used the Meguiar's scratch remover too, and it did an okay job. Sounds like I just need to go back and do it a few more times to make sure it works it's way through the residue left by the badges.
Old 10-09-2008, 11:12 AM
oleblue's Avatar
Sounds like the meguiars is the ticket. I'm gonna pick some up today.
Old 10-09-2008, 12:32 PM
jusbecuz's Avatar
I can tell you this about that soft little white sponge, they do far more than you would ever imagine. I had some paint on my arm that I couldn't get off washing, and there was a Mr. Clean eraser on the sink, so I used it on my arm. The paint came right off, but a few hours later my arm was raw and hurt like heck. It scabbed up and took 2 weeks to heal. I would definately not use one of these on a clearcoated surface, as you don't know how much damage is being done until it is too late.
Old 10-09-2008, 12:51 PM
Dwitt0187's Avatar
off subject for a sec but what the heck is in the magic erasers they work great on getting marks off of things but there really seems to get nothing there other than a funny feeling sponge.
Old 10-10-2008, 12:13 PM
redspider's Avatar
try a clay bar kit
Old 10-10-2008, 12:27 PM
oleblue's Avatar
Picked up some scratch x today, gonna give it a try. We'll see what happens.
Old 10-11-2008, 07:06 AM
mpracehemi's Avatar
Now on my truck which baked in the baker, ca. area for 3 yrs., I used acetone very carefully. It did not eat at my clear at all and removed the out line. I don't even have any color diff./variation. Can't tell that I had any badges. I bought the acetone at home depot, home repair chain.
Quick Reply: Debadged and still have the outline
