Death Wobble
Old 11-15-2006, 05:37 PM
doug60's Avatar
Death Wobble
The Death Wobble has come to visit once again.
shocks are 100,000 + bilsteins.
All front end parts are tight. Allignment just done 3 degrees positive caster.
Violent Wobble.
Shop could not move Caster to max spec ( frozen bolts & cams)
What to do . Should I buy new trailing arms or is there a less expensive way out. Will new shocks do it?
Two shops confirm Track bar is tight . Thanks for your help, doug
96 / 12 valve 225000 miles 5 speed
Old 11-15-2006, 06:12 PM
DynoDynamicsNE's Avatar
New shocks all the way around would be a good start.
But what do I know? This is my first post...
Old 11-16-2006, 12:29 AM
97ramctd's Avatar
i've seen two do it now a 96 and my 97 tires seem to be the culprit on ours but may not be on urs.
Old 11-16-2006, 11:14 AM
bek
bek's Avatar
Check those ball joints, my wobble came from one worn upper. Replacing your control arm bushings can be a monster if everything is frozen. I had to slip a cutoff wheel in between arm and bushing and cut them out, one is still in there.
725Gus
03-06-2014 09:49 AM
Trooperthorn
11-30-2010 12:06 AM
Jezzhuntin
04-11-2007 04:52 PM
smokindodge1996
02-13-2004 08:54 PM
moneypit
09-23-2003 06:06 PM
Quick Reply: Death Wobble
