Dead battery??
Old 09-04-2009, 12:13 AM
WL.
WL.'s Avatar
Dead battery??
Last month, I had to jump the battery. I've had no problem for about 3 weeks, until 2 days ago. I had to jump it to go to work. After work, she started just fine. The next day, dead again!! I went to jump it and noticed that one of the cables were loose. I tightened it and had to jump it again. Tyhe batteries are Optima red tops and are not even a year old yet. The only thing I have that draws continuous current is a rechargeable Maglite, which I have taken off of the charger for 2 weeks now. If it was the alternator, would it be acting this way or just be dead, as it should be. It is driving me nuts because I can't figure out what or where the cause is? Any clues??
Old 09-04-2009, 02:27 AM
kokalit's Avatar
Can't tell from your post, but did you fully charge the batteries after the jump start? Just driving around is usually NOT enough to recharge a drained battery, much less two, unless you go on a really long road trip. The loose cable MAY have kept the one battery from getting a good charge from the alternator and thus putting most of the starting load on the other one. I would suggest getting both batteries checked and then fully charged and then install and tighten the cables and see what happens then.
Rancher99
04-18-2011 09:46 AM
jesussaves
11-07-2010 06:55 AM
EdmontonCanada
10-10-2008 11:37 AM
taildragger
38
12-19-2006 09:49 AM
planejane
08-23-2004 03:17 PM
Quick Reply: Dead battery??
