DDP injectors
Old 11-12-2010, 05:32 AM
zack_76401's Avatar
Location: Lingleville TX but active duty Air Force all over the world currently
DDP injectors
Any reccomendations on these injectors? Can I go straight for the 80 hp injectors instead of buying 25 or 40 horse injectors? What supporting mods will I need to run these injectors? I plan on new turbo just wondering if EGT's will be managable with these injectors. Are there better ones out there for the money?
Old 11-12-2010, 08:27 AM
92betsy's Avatar
From what I've read SDX have a better spray pattern and they are alot cheaper than DDP injectors. http://www.southerndieselx.com/index...y&path=309_332 And I'm pretty sure you can just go for any size injector you don't have to step up on them for the bigger ones.
Old 11-12-2010, 12:45 PM
92smokin blacky's Avatar
You can run bigger injectors just fine, but if you want more power with them then turn up your pump too. You might get a little hot with a stock turbo and bigger injectors an pump turned up. I think I'd turn up pump first then go with a better turbo then injectors. No point havin all the power and not bein able to use it cuz you cant keep it cool.
Old 11-12-2010, 06:22 PM
Jer12377's Avatar
Location: North Haven,CT "Living in occupied teritory" & Barton,VT
Question Whats the size?
What size are DDP 80hp sticks (example-5x18=001272).? The chart on 1stgen.org http://www.1stgen.org/viewtopic.php?f=4&t=1363 only says they are 65lpm
Old 11-13-2010, 03:41 AM
zack_76401's Avatar
Not sure on the size, they just say 80hp....Ill look into this.
Old 11-13-2010, 03:45 AM
zack_76401's Avatar
Im going to turn up the pump, 3200RPM spring and a Denny T pin.
Old 11-13-2010, 06:17 AM
KD93's Avatar
Zack, the first thing you should get is a pyrometer, (says he who doesn't have one... ) If you turn your pump up, it'd be a real good idea to keep an eye one your EGT's.
Old 11-13-2010, 06:37 AM
zack_76401's Avatar
I have the pyrometer and boost gauge ordered....
Old 11-13-2010, 06:46 AM
KD93's Avatar
Good work. Now you can go nuts!
Old 11-13-2010, 09:06 AM
JQmile's Avatar
DDP's are expensive, but a very good injector, especially if you're into fuel economy and low smoke.
Old 11-13-2010, 10:20 AM
zack_76401's Avatar
Im into daily driving, good milage low smoke and power...but arent we all?? How hot is too hot on a stock piston? 1200 sustained??
Old 11-13-2010, 03:08 PM
KD93's Avatar
They reckon 1250° is the safest maximum sustained temp.
silverbullet02
04-24-2006 04:08 PM
fishin fever
03-23-2006 02:04 AM
WhiteSport600
02-16-2006 05:32 PM
Syndicate
58
02-13-2006 09:42 PM
Quick Reply: DDP injectors
