Dana 60 Rear: Fluid capacity, fluid weight, additives, gear questions
Old 01-16-2008, 10:43 PM
LockedandLoaded's Avatar
Basically, exactly what the title says. I'm doing my clutch tomorrow and figured I'd fix up my leaky rear diff cover gasket while I got it up on my friend's lift.
Anyhoo got a few questions.
1.) How many quarts of gear oil do I need to pick up?
2.) What's the preferable weight (80w90, ect)?
3.) Anyone got a picture of what limited slip diffs look like? Dunno if PO rebuilt with a locker or a oem LSD, so I dunno if I need LSD additive or not.
4.) What kind of RTV should I use (gray, blue, black, or red)?
If it helps, my truck doesn't do much towing, though I do haul between 1-2k lbs of metal in the bed every other day. See's about 200 miles a day. Tendency to drive a little aggressive. Thanks yall!
Old 01-16-2008, 11:02 PM
torquefan's Avatar
By the description of your truck, it will be a Dana 80 in the rear. It holds right around 4 quarts, so you may want to have 5 on hand.
It will have come from the factory with 80w90 in it. You can continue to use that, or you can upgrade to a 75w90 synthetic. I wouldn't bother with 75w140 unless it is used to tow heavy.
My favorite sealant, and the best on the market (in my opinion) is Permatex Ultra Grey.
Sorry, don't have a picture of a LSD. The next guy might.
Old 01-17-2008, 12:29 AM
Buckshotram's Avatar
You either got a dana 70(auto) or 80(manual trans) they hold around 4 quarts and fill to 1/2inch below fill plug. Ive used the gray and blue with no problems.
Old 01-17-2008, 05:57 AM
sabercat's Avatar
Any addiditive to the lube also?
Old 01-17-2008, 06:33 AM
Hmm could have sworn it was a 60... Oh well, we'll find out today after work! Oh yeah, any word on additives and lsd picture? Thanks a million yall!
Old 01-17-2008, 11:32 AM
Dhorn33's Avatar
I used inexpensive farm store 80/90 gear lube and a bottle of whatever lsd additive they had on hand when I swapped my gears. Total cost was around $15.
Old 01-17-2008, 11:40 AM
Pickin on the wrong admin...
Diesel Dave2's Avatar
Dana 80 in the back.Dana 60 in front....Don't overfill your diffs or you will land up having oil leaking past the seals...
Old 01-17-2008, 02:51 PM
Ru rammin 2?'s Avatar
I used valvoline durablend on mine. It comes with the proper additives for LS diffs. mine's an 80 and I think it took just under 4 qts. Mine has LS and I've not had any probs. If you're worried, mine said it on the build sheet under the hood. axle type, size, ratio, and LS.
Firstgenfanatic
09-16-2010 01:37 AM
riderdog
17
02-11-2010 10:07 AM
Bobcat698
05-18-2006 04:09 PM
Ripper406
12-14-2004 07:45 PM
mcevins
07-03-2003 02:06 AM
Quick Reply: Dana 60 Rear: Fluid capacity, fluid weight, additives, gear questions
