daily driver--not anymore
First of all I"m forunate I have a company supplied vehicle.
I think I have built my truck into somthing that is not fun to drive every day.
this 4th of july weekend I took a long trip with my personel truck,this was a recreational trip. when I return home I had realized I bhad lost somthing and needed to go back, the work truck standard no lift chev was much more comfortable.
so my question to the team is, is your truck still comfortable as a daily driver ??
Mine is stock and I drive the crap outa it, I do have a little car to run abought in but its days are numbered. My thoughts are if you modded it to the point its no longer fun to drive you went to far and need to remove what ever nesasary to make it more plesent to drive. Modding it the point its no longer plesent to drive is kinda counterproductive isent it??
Curious, what made it uncomfortable? Was it a suspension & tires or having the performance mods? I ask because the some of the mods in your signature are on my to do list.
I took a fairly long trip this weekend as well. The only two things I was disappointed in were the sloppy stock torque converter (read built trans) and my egt’s went higher than I would have liked pulling some of the hills (read twin turbos).
de-tune it a bit for daily driving, get Thuren to valve you some Kings to soften the ride (still cant compare a dodge to a GM with their independant front end) and get seat foam re-done on the drivers seat and you will be back to smilin!
I put most of my road time in my 97 up to 12 hours a day and don't have much to complain about really. I mean it may not have all the whizzy stuff of my 08, but it works well on the roads I drive, some gravel, highway, back road bush etc.
The 08 is a great highway driver as well for me as its used for family use only.
I think it is too easy to see a mod out there and not realize how much is affects the daily use of the truck. Some mods are just performance and that's it but you sacrifice the ease of just getting in and go. The 12V is more like that as dialing back is not as easy as selecting power level 2.
the truck ride is not bad just by comparison to a stock set up the stock suspension has a much smoother ride.
Evildiesel
11-18-2005 11:29 AM
CTD_Neil
18
11-07-2005 09:18 PM
hellotbone
16
11-06-2002 03:18 PM
