Dad Blamed Motor Mounts
Old 12-11-2006, 10:21 PM
mhuppertz's Avatar
Too bad we can't use exclimation marks, "at" symbols, pound signs, and such in our posts, because I don't think I can truly express my feelings about what has happened with my motor mounts without the symbols.
Any loosening on that point Dave?
Old 12-11-2006, 10:45 PM
Begle1's Avatar
Symbols? You can use symbols, they just need to be unorthodox.
Or just type random words. They work as swear words.
Grundle Uthart gimble kert pouillant tous varkker slart!
(Oh, my mouth tingles with the flavor... )
Old 12-11-2006, 11:08 PM
mhuppertz's Avatar
OK, I'll do my (self edit) best.
My engine started to make a grubling sound under throttle angle, and I figured out pretty quick that my engine was listing to starboard and hitting my bypass filter with the alternator! I shined a light down at the
mount (because nothing ever breaks in the daytime when it's warm) and found that the restraint tang are totally bent.
I bought one new mount (that's all they had, I'll get the drivers side mount from Napa) I realized that the entire mount is supposed to be encased in rubber. Mine have never looked like that as far as I can remember...
Now I get to lay on a frozen slap and try to find a combination of 6x6 sections that will get my 3 1/2 ton jack to pick the engine up off of the wasted mounts. They are both toast by the way.
Anyone else had this issue?
I'm going to torque the engine to the frame with a giant wratchet strap until I can get to the nasty job....
Old 12-11-2006, 11:47 PM
Diesel Junkie's Avatar
My rig is a 92 with about 180+K and my motor mounts look fine. The rubber is fully intact.
My only complaint is that at around 100k, the passenger side mount sheared the bolt that holds the mount to the bracket. I think i remeber these are only 5/16" bolts in double shear on each side. I remember thinking that a 5/16" bolt is rediculously small to be holding up a cummins. I put in a grade 8 in its place, and havent had any issues since.
Old 12-12-2006, 09:56 AM
timb's Avatar
Mark, Have you had a problem with oil getting on the mounts for a prolonged period of time? Because oil will deteriorate the rubber. I have over 350,000 on mine and they seem to be fine. But mine has never leaked much oil. It just uses it.
Old 12-12-2006, 11:25 AM
brainfade's Avatar
I replaced both engine mounts plus the trans mount bushings in mine. Helped alot with the clutch engagement chatter, but it's like sitting in a paint shaker when I start it on a cold morning. FWIW watch the clearance between the head and the firewall when you lift it to change the mounts. I used NAPA mounts, they seem to be holding up fine.
Old 12-12-2006, 07:17 PM
You can use symbols, you just can't spell anything with them.
From the site rules:
In addition, for the use of this forum, profane posts should be considered those completely spelled words, or partially spelled words with use of keyboard symbols that suggest a profane meaning.
So %#@! (comic strip cussing) is fine, but using symbols to avoid the censor software is not.
Old 12-12-2006, 07:47 PM
mhuppertz's Avatar
Could be that. Now that I am looking at it, the rubber looks in tact, so I'm not at all sure why my engine is now laying over on the &^#@$& turbo outlet! (Thanks Dave, I love cartoon cussing. Truth be told I very rarely let a cussword slip.)
I tried to turn the engine over in reverse with the brake on to lift the engine enough to jamb a 2x4 between the head and the block to save the turbo! Couldn't get that to work.
I'm stumped, and am not happy.
Old 12-12-2006, 08:01 PM
Begle1's Avatar
No it isn't. I've had comic strip cussing edited out of my posts before.
Old 12-12-2006, 08:58 PM
2stroke's Avatar
did try to jack it up with a 2x4 on that side?
Old 12-12-2006, 09:24 PM
mhuppertz's Avatar
Not yet. It's been very cold. I hope I didn't tweak the crossmember/frame.
Old 12-12-2006, 09:28 PM
flashgordon's Avatar
The turbo out let elbow is what will ware out!
Old 12-12-2006, 09:56 PM
12valve@heart's Avatar
Can you start it, lock the brakes, and slip the clutch in reverse to shift the motor over and then kill it in gear?
Old 12-12-2006, 10:06 PM
mhuppertz's Avatar
I tried but the torque stress from the mounts overcomes the compression of the engine and it turns back.
Old 12-12-2006, 10:11 PM
loch's Avatar
My sisters truck 93 dually does same thing. I replaced motor mount and its again laying over. both mounts as tranny mounts are new, i tried lift motor on passenger side to try slip it sideways but to no avail. I havent had time get back on it.
Quick Reply: Dad Blamed Motor Mounts
