Cylinder cutout?
Old 03-25-2011, 09:48 AM
caliaudio's Avatar
Cylinder cutout?
Does anyone know how I can do a cylinder cutout test on these engines in order to determine which injector/s are defective?
Old 03-25-2011, 09:53 AM
no_6_oh_no's Avatar
Yep, cylinder cutout and cylinder contribution tests are avaialble with a scan tool that supports the ECU and programs.
Old 03-25-2011, 09:56 AM
caliaudio's Avatar
Know any cheap ones? I was hoping a smarty would do it, that would give me the extra little push to buy one....
Old 03-25-2011, 09:58 AM
no_6_oh_no's Avatar
You might check the computer based ones and see if they give you the ability to do that. Other than a dealer tool and a Modis not sure what can do those functions. Pretty sure if it can that they aren't going to be cheap though.
If its a one time shot, a dealer or shop that has the tools might be your best shot to get that data.
Old 03-25-2011, 10:00 AM
caliaudio's Avatar
Thats too bad thanks for the info
Old 03-25-2011, 10:06 AM
firestorm's Avatar
Which engine are you working on? The old school way, if you can get to the injector lines is simple. With the engine running, and being careful, crack an injector line loose. If the engine runs differently, that cylinder system is working properly. If it has little, or no effect, then that injector, cylinder, or fuel line, is the problem. Just watch yourself on top of the engine. You don't have to take the fuel line off, just crack it loose to relieve the pressure, and protect yourself from the fuel spray.
Old 03-25-2011, 10:10 AM
caliaudio's Avatar
Oh one more thing, Is it possible to do just a soleniod test on the injector? When these go bad I have a hunch typically its the tips on them and if thats the case maybe I can just send them to F1. How would I determine if the rest of the injector is good?
Old 03-25-2011, 10:11 AM
caliaudio's Avatar
5.9 CR would not be able to use that method.
Old 03-25-2011, 08:37 PM
no_6_oh_no's Avatar
Thats a BIG on a CR engine
Yes, you can ohm the solenoids and see if they are good. Generally on a DVOM that is accurate within .5 ohms they read .5 ohms and are good. Doesn't catch intermittent problems when warm but will show a problem if the solenoid is going.
There are pintel seats, check ball, return orfice, etc, internal to the injector that seperate a "good" injector form a "bad". If your doing new tips is highly advisable to have the injectors flow balanced and adjusted for the new tips and that takes expensive equipment like F1, II, Exergy and the rest have.
realest
01-18-2010 02:37 PM
qwkness
09-21-2006 02:02 PM
JD730
16
07-13-2006 08:00 PM
leonesm
08-31-2005 01:54 PM
GOTMEAT
03-15-2004 08:28 AM
Quick Reply: Cylinder cutout?
