View Full Version : Cut delivery valves
southernsmoker
03-30-2004, 10:30 AM
Couldn't a person take a set of delivery valves to a machine shop and have them turned down to the same size as lasered dv's. It would have to be cheaper but would it work?
southernsmoker
03-31-2004, 11:08 AM
No takers on this one?
dodgeman01
03-31-2004, 12:57 PM
yes it would work. just have to find a place that can do it. I have a friend that says he knows a place to do it. Will figure out later if it really works as well as said to.
DM01
Sidewinder
03-31-2004, 06:35 PM
I keep hearing about diverter valves and delivery valves on this site.
Where are they? What do they do? Why would you change them. What is a "LASER CUT" DV and can I make my own?
Thanks!
gunracer1
04-01-2004, 11:16 AM
i think a good machine shop would have no problem cutting a set of DV's. they are very, very hard, and i have no idea how they would lazer cut a set. the big question is how much to cut them. i have looked at 2 set of cut DV's. both were under cut about the same under the head. but it does not take much of a cut to make a big differance
roadranger
04-01-2004, 03:25 PM
Yeah, what Sidewinder said^
What's a delivery valve?
Moose10
04-01-2004, 09:50 PM
Can anyone shed some light on this for us? Delivery valve ???
southernsmoker
04-01-2004, 11:26 PM
Delivery valves are located in the delivery valve holder. With that being no help to you, the delivery valve holder is what the injection line connects to on the pump (P-pump trucks only). The valve is held down by a spring in the DV holder. When the pump cam pushes the plunger up in the barrel in the pump, the barrel pressure overcomes the spring seat pressure that holds the DV down. The DV is pushed open and fuel is permitted to enter the injection line. Cut valves allow more flow to enter the line when the DV is opened. There is a delivery valve for each injection line. Hope this helps. SS
Moose10
04-02-2004, 12:13 PM
Thanks SS, good info to know if I ever pick up a 12v. The P-pump trucks are all 12v right.
southernsmoker
04-03-2004, 12:42 AM
Yep. There 12V unless they have been converted.
