Cummins running REALLY BAD!!!
Old 11-21-2003, 11:28 AM
Diesel-Dan's Avatar
Howdy all! Got a question. We got a truck in last night and its got some weird symptoms. Its a '02 3500 with about 25K on it. Here is the deal. Dude has air intake, 4" Exhaust-dual 3" out, an Edge Drag Comp Box with tapped wire and a full set of A-pillar gauges. Quote "I was driving down the road and upped to setting four and then there was no power at all and speed dropped. I had to limp it home. It would idle but sounded like it dropped a cyl or two." End Quote. We listened to it and its sounds bad at idle. Not hitting on all 6 and there is some white smoke. BUT when driven (with out the box plugged up) seems to run ok at higher RPM. Any thoughts?
Old 11-21-2003, 11:45 AM
Chip's Avatar
Re:Cummins running REALLY BAD!!!
Could it be that the fuel pump just gave up ??
Old 11-21-2003, 11:47 AM
Diesel-Dan's Avatar
How does that accout for it idleing bad and running good at higher RPM? Lift Pump? Injection Pump? Heck...we need more tools! haha! O yeah....we did take the box off....did not make a lick of differance.
Old 11-21-2003, 11:50 AM
Chip's Avatar
Yea, having the right tool(s) makes all the difference in the world !!
Old 11-21-2003, 12:10 PM
Copenhagenjunkie's Avatar
Although my truck is stock your symptoms are identical when I lost my injector pump.
Old 11-21-2003, 12:51 PM
Diesel-Dan's Avatar
As far as i can tell its normal at higher RPM. Great...that is no good new! SO if indeed it is the pump...how much of a job is it to remove? Never really went down that road. AND what upgrade pumps they offer for the VP?
Old 11-21-2003, 01:15 PM
billg's Avatar
Did you check to see if any codes were set?
P0181 Fuel Injection Pump Failure
P0215 Fuel Injection Pump Control Circuit
P0216 Fuel Injection Pump Timing Failure
P0251 Fuel Injection Pump Mechanical Failure Fuel Valve Feedback Circuit
P1688 Internal Fuel Injection Pump Controller Failure
This one could be brought on by a sensor going bad.
P0217 Decreased Engine Performance Due To Engine Overheating Condition
More information on codes at: http://www.troublecodes.net/chrysler/
Hope this helps
Old 11-21-2003, 01:17 PM
Diesel-Dan's Avatar
VERY HELPFULL! Thanks much...still tring to locate a scantool to get the codes out.....acctually i am going pony up the dough and buy one! haha.....
Old 11-21-2003, 01:45 PM
billg's Avatar
There is a way to pull the codes on the digital speed-o. I don't know how but someone here will. I use the superchips programmer.
http://www.superchips.com/html/produ...sel_trucks.htm
I got mine from West Texas Turbo Diesel http://www.westtexasturbodiesel.com/
He has good prices.
Old 11-21-2003, 01:50 PM
JStull's Avatar
put the key in the ignition and turn the ignition on and off (just turn to the "on" position, don't bump the starter!) two times and turn it on and leave it on on the third time. then watch the place where your odometer reading is usually shown. it will display any codes thrown.
-Jason
Old 11-21-2003, 01:51 PM
just a thought- it could be the wastegate.
As stated earlier I had the same symptoms and it was the VP-44 but I also had a bad diaphram on the wastegate.
Old 11-21-2003, 02:09 PM
Diesel-Dan's Avatar
But as far as i know.....the wastegate would not cause it to miss or run VERY LOPEY at idle. COOL HINT on the Code thing! Love secoret codes! I work at a accessory shop, dont like the Supertuners for the Dodge. Its a hit or miss type deal on that one. Work on too many OBD-II trucks/cars and need to be able to read/reset codes on all. (Mechanic on the side!) Codes I got are as follows (AND NO i have not looked at the last post that was posted a few ago, but i will! haha):
1492 ; 1693 ; 0237 ; 1690 ; 0236 ; 1693
Thanks much!
Old 11-21-2003, 02:21 PM
billg's Avatar
Here are you codes
P1492 Battery Temperature Sensor Voltage Too High
P1693 DTC Detected In ECM Or PCM
P0237 MAP Sensor Voltage Too Low
P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor
P0236 MAP Sensor Too High Too Long
Good Luck
Old 11-21-2003, 02:29 PM
Diesel-Dan's Avatar
Since when are they concerned about the battery temp...and where the heck is the sensor?!?! Here is my guess at this...the map sensor codes are set due to the box. they could be ignored. The batt temp....well i don’t know about that one...but safe guess that is not causing my prob. DTC in PCM and ECM....well that is a generic code that probably pops with you get a code...again a guess. Fuel injection pump CKP Sensor Does Not Agree with ECM CKP Sensor is the one that worries me...but i did not get any pump failure codes...which is good I guess! Any thoughts would be appreciated as well are the current replies!
Old 11-21-2003, 02:42 PM
Diesel-Dan's Avatar
...here is a thought.....blown head gasket between 2 cyls.........now how do properly diagnose the problem. I cant find any spark plugs to pull to check compression..........It is white smoking like a big dog. Smells bad too. Any suggestions?!
Quick Reply: Cummins running REALLY BAD!!!
