Cummins Repair/Engine Manual?
Old 03-23-2011, 01:57 AM
Gmanndodgeguy's Avatar
Been thinking about tackling my own engine work and was wondering if anyone knew of a good resource for this? I'm thinking about doing a cam swap, injectors and possibly a twin kit but I'm not sure of my capabilities on it. If I was able to read up on it bit and had some really good engine information I'd be able to make a better decision.
Thanks!
Old 03-23-2011, 04:23 AM
papaduck's Avatar
Geno's sells the repair manuals on disk.
Old 03-23-2011, 04:46 AM
6spd05Dually's Avatar
Thanks!
Alldatadiy.com is the most trusted resource. Most major repair centers use the site. That site for 1 year subscription cost 29.95. Also, if you have a local Cummins distributor in your area, you could go buy the repair manual for your engine. You will end up getting the manual on the L10 Cummins and a few other engines, but a good deal at a little over 100.00 bucks. Best of luck!
Old 03-23-2011, 04:16 PM
appreciate the replies dudes. I'll give them a try!
Old 04-07-2011, 01:37 AM
amandrew325's Avatar
Hi, tried cummins repair manual 3001101 for $25 and that works well. As i observed, free manuals are just like general manuals and i always recommend getting the paid one. it includes:
3100310 corrosion resistor of cummins diesel engine
3608315 corrosion resistor of cummins diesel engine
3680433 corrosion resistor of cummins diesel engine
4061241 oil of cummins diesel engine
WF2075 corrosion resistor of cummins diesel engine
WF2076 corrosion resistor of cummins diesel engine
WF2074 corrosion resistor of cummins diesel engine
3316053 corrosion resistor of cummins diesel engine
3831133 corrosion resistor of cummins diesel engine
3100309 corrosion resistor of cummins diesel engine3844234 corrosion resistor of cummins diesel engine
WF2126 corrosion resistor of cummins diesel engine
4907485 corrosion resistor of cummins diesel engine
Auto repair manuals
BuckeyeRed
10-24-2007 09:55 PM
drewblood
08-23-2007 04:25 PM
APD
02-28-2005 05:17 PM
Geico266
03-11-2004 03:58 PM
Quick Reply: Cummins Repair/Engine Manual?
