PDA
View Full Version : Cummins Ramcharger
Trooperthorn
04-29-2008, 11:29 PM
Well, I stalled on the cummins crew swap. Can't find the time to get into the shop. When I do, I am stuck in a traffic jam. The frame is no longer on wheels. The ramcharger does not move. The new 4 door cab is on the floor with a cummins, auto, 205 package. There is other misc. carp that does not belong in a shop, like an old school, school desk. There is a dead tranny out of a 89 1/2 ton Dodge...whatever, too much stuff. So, the new plan is to do a quickie drop of the cummins auto package into the ramcharger and get it and engine out of the shop so I can move around. Then dive into the crewcab again. Before I can do the rc, I need to paint the crew frame and put the running gear under it so I can roll it outside. Anyway, check out the new blog. I've seen a few rc cummins swaps, but not too many with the removable top. [guitar] Should be fun.
farmer0_1
04-30-2008, 12:45 AM
and i am still spinning my c cab wheels. good job very encouraging to see you take on two at a time. going to find a nice saturday to stop by.
Alwaysworking
04-30-2008, 12:57 AM
cool, i was woundering when the r/c would start, now when will it start?
Fred Swanson
04-30-2008, 05:54 PM
I can only wish I had that kind of time to tackle 2 different ones at the same time
Trooperthorn
04-30-2008, 11:28 PM
Ha ha ha. Time, what's that. Work, kids on two different track teams with different meets and practice at different places. Graduate school work. Making fuel. Sleep. Yeah, time would be nice. Nice thing is, work stops on June 16 and doesn't start again til the end of Aug.
Alwaysworking
04-30-2008, 11:55 PM
just cut the sleep part out or change when you do it, do it in class. [laugh]
Fred Swanson
05-01-2008, 12:00 AM
Yeah, I know what you mean with 2 kids, activities, work, house projects, working on other people's trucks too. And then finding that elusive time to work on your own projects.
Alwaysworking
05-03-2008, 11:47 PM
engine in yet? or do you still have to paint your cc frame
Trooperthorn
05-04-2008, 01:33 AM
Lets see, in the past week I went in the shop a couple of times to grab my skimpy set of metric end wrenches so I could replace the alternator ($116 exchange:() in the 300d. Seems like I spend half my life doing stupid stuff like going back to napa to get the pulley shaft key out of the alternator core. [duhhh] I was smart enough to pull the pully, but too stupid to grab the key.
Alwaysworking
05-04-2008, 01:35 AM
next time try waltz they rebuild those things
Trooperthorn
05-04-2008, 01:49 AM
I would have had it rebuilt, but I wanted to get it done today. Anyway, its only money.
Alwaysworking
05-04-2008, 01:57 AM
next time say yor with triple A they get good discounts[laugh]
Alwaysworking
05-04-2008, 02:01 AM
maybe you should change your name to bitesoffmorethancanchew
farmer0_1
05-04-2008, 12:32 PM
heck my project list has an "edge of the world" to it. when it gets to long the older projects "fall off" . if i am not 2 years behind i would feel like i'm not taking on enough.
Trooperthorn
05-23-2008, 07:01 PM
Lifted the body the rest of the way off yesterday. That was fun with the engine crane, by myself. I lifted the body, but the crane was in the way to roll the frame out and I could not back the crane far enough (poor planning). So I put a floor jack under the rear end and slid the frame out the side.
http://www.dieseltruckresource.com/pics/data/500/medium/DSC01824.JPG
The engine/tranny/t-case combo is pretty heavy (duh). The hoist did not want to roll. even when the engine was just two inches off the floor. The whole mess wanted to tip over when the engine got to swinging while I was moving it. So, I got the hoist in position with the weight as low as possible. Thien I raised it up and rolled the frame under it. It would have been easier to change the springs and axles without the power plant in place, but with the 5 inch lift and 35" tires, I would have had to lift the engine 6 or 7 inches higher. This was scary enough.
http://www.dieseltruckresource.com/pics/data/500/medium/DSC01830.JPG
Except for the squashed springs, the package looks like it was meant to be in there. The factory springs, no doubta little tired, are about an inch and a half from the bump stops. This is without the body and front-end.
For those of you who know what I am talking about and hav been wondering about the hole verses the slot for the motormount on the driver's side of the engine cross-member. I first eased the mount stud into the factory hole on the left, the lowered the rigt mount stud into the factory slot. It went in like butter. I thought I would need to slot the other hole, but, I did not.
The 1977 tranny cross-member looks to be about an inch too close to the front, and the mount holes are too narrow. I will swap it with the one from the 1992 donor w250, as both frames are 6 inches deek under the cab area.
http://www.dieseltruckresource.com/pics/data/500/medium/DSC01839.JPG
I included this pic to put the short wheelbase int perspective. Alwaysworking thinks I should just mount the rearend to the t-case [laugh]. I haven't measured it yet, but I think the rear driveline will be shorter than the front.
http://www.dieseltruckresource.com/pics/data/500/medium/DSC01840.JPG
Check my blogs for more details about the projects. I'm grinnin' bigtime.
Fred Swanson
05-23-2008, 07:42 PM
My rear shaft with the thicker engine adapter plate for the 47RH, is right at 31 inches.
farmer0_1
05-23-2008, 09:59 PM
anytime you need to use a second engine hoist let me know its just sitting in my shop. give me a reason to stop by. sure don't want you getting squished with that much work ahead of you or a flat oil pan.
Alwaysworking
05-23-2008, 10:03 PM
or call me, i'm a little closer, but you'd have to plan ahead.
Trooperthorn
05-26-2008, 11:03 PM
Worked on the rc some more today. A couple of days ago, I discovered that the tail housing was broken where it bolts to the Transfercase.
http://www.dieseltruckresource.com/pics/data/500/medium/DSC01841.JPG
http://www.dieseltruckresource.com/pics/data/500/medium/DSC01842.JPG
I took the tailhousing to alwaysworking. He will attempt to weld it up for me. He also has my Dana 60. He is welding on the new inner C in place of the one with the broken lower king pin.
Tiday, I killed my kdp. It was not out that much, but I was able to drive it in about an eight of an inch. Then I peened the case. Rhe most scary part was that te lower right (left when facing the front of the engine) case bolt was backing out. I could turn it with my fingers. I locktited and retorqued the case bolts. I was not able to get an timing case/crank seal (Memorial Day), I was not able to button it back up.
I worked on the power steering today as well. Since I am using the 1977 steering box and the ends are different than the 1992, I had to change some things. First, I used the 1977 low pressure line. This just hose clamped to the back of the pump. The problem lies with the high pressure line. After some study, it looks like I can cut back th steel part of the pump end of the 1993 hose, slip on the 1977 nut, and use a double flare tool to make a flare that will work with the old style pump and nut. Since I do not have a double flare tool, the completion of this part is on hold.
Also today, I removed the AC compressor and lines from the '92 ctd in the ramcharger and installed it on the '93 ctd that is still sitting in the donor frame but will go into the crewcab when the rc gets out of the shop.
Coming up, I will work on the fuel lines and patch a hole in the top of the tank where there used to be a vent. I plan to plumb the return into the fill tube vent.
Thats all for now, Eric
Alwaysworking
05-27-2008, 12:41 AM
we got the guts out, of it and is in the solvent tank, three snap rings and it falls apart.
i and going to bolt the housing to my 205 to keep all the parts where they need to be for welding.
farmer0_1
05-27-2008, 02:40 AM
always cool to see folks working for a common goal. nice job alwaysworking.
Alwaysworking
05-27-2008, 01:54 PM
found out today that the case is close to 50 bucks used and in stock no waiting just would have to drive to portland to get it.
Trooperthorn
05-27-2008, 10:52 PM
Yeah. Thanks for finding that for me. That will be a better way to go.
Alwaysworking
05-27-2008, 11:40 PM
i'll go up and get it tomarrow, i need one anyway.
Trooperthorn
05-31-2008, 12:08 AM
Had a little party in the shop yesterday. Alwaysworking and his dad brought me my new OD housing. Shortly after arriving, Confedpirate showed up in his new 1973 crewcab 4x4.
We put the overdrive back on and hung the transfercase. After moving the tranny crossmember back one holethen swapping the bracket end for end and monkeying around for a while, we finally pulled out the hot knife and slotted the holes in the crossmember in order to get things to mount up right.
I really appreciated the help and company. The np205 is a bear to wrangle yourself. Even when you have the body off.
http://www.dieseltruckresource.com/pics/data/500/medium/DSC01855.JPG
Alwaysworking
05-31-2008, 12:14 AM
looks to me like you need to dirty up that OD housing. it doesn't match.
also i still like the dually ram charger idea, with a half cab, that would be cool and i have never even seen a dually RC
Alwaysworking
06-01-2008, 04:41 PM
what radiator are you going to use?
Trooperthorn
06-02-2008, 12:07 AM
I have 1 radiator between the two projects. When I get to it, I will see if my 440 rad will work with the intercooler. Or I will use the one I have, and buy a new one for the crewcab.
Trooperthorn
06-03-2008, 11:13 PM
Last weekend I played roulette with the front axles from both of my projects and a donor vehic. The half-ton full time out of the rc is now supporting the dually parts frame. The Dana 60 out of the dually frame is now under my crewcab conversion frame. And, the 3/4 ton Dana 44 from the cc is now in the holding up the ramcharger with the cummins. The d44 had 4:10 ot 11 gears and warn hubs, but is only temporary. When Alwaysworking is done with my broken Dana 60 single wheel with 3:54 gears, it will go in. I mainly did the swap now to get the 5" superlift springs under the rc.
http://www.dieseltruckresource.com/pics/data/500/medium/IMG00023.jpg
Since installing this, I hooked up the power steering and drag link, installed the front drive line, hooked up the front brakes, swapped the fuel line from the right side to the left, and dropped the fuel tank.
To use the old style power steering lines that fit the old style steering box, I had to swap the fitting in the back of the ctd pump with one from a 70's vintage fitting. Once done, the old lines bolted right up.
The front drive line from the ctd donor fit the dana 44 with no modifications.
The brakes were the same story.
The fuel line moved over without incident. I still need to run a return line.
The fuel tank is pretty crudded up. The internals were rusty and there was about 4 gallons of nasty gas inside. Not sure where to go with it. I will see if I can find another guage sender and clean up the fill tube. Or, I may look for another, newer tank. I have an extra ctd sending unit, but I do not know if the guage sender would be compatible with the '77 guage in my dash. I suppose the sender is just a resister. Don't really know.
Thats the extent of the work for now.
Alwaysworking
06-03-2008, 11:38 PM
hint, hint, nudge , nudge.
Trooperthorn
06-04-2008, 12:02 AM
no hint or nudge implied. I actually want to drive it with the 4:10, then with the 3:54 to see the difference. Get your own trucks where you want them, then worry about me.
Alwaysworking
06-04-2008, 12:31 AM
ya i was kidding, as long as you dont do serious off roading or are really hard on things the 44 should hold up for quite some time.
Trooperthorn
06-06-2008, 01:46 AM
So are you saying no Tough Trucks this weekend?
Alwaysworking
06-06-2008, 02:05 AM
no jumping and tuff trucks is on fathers day at i think at lebonon speed way and the the day after is mud bogs at sheridan
Alwaysworking
06-07-2008, 02:01 AM
ready to put the body on yet?
Trooperthorn
06-07-2008, 02:10 AM
I did not get the axle in yet. Got invited to dinner. Will get it in tomorrow. Then I will work on the exhaust. After that, the body. Thinking about running the true 3" pipe off the turbo and past the t-case then split it into my two 2 1/2 from the almost new 440 pipes. Otherwise i do not have enough pipe to get it out from under the truck. What do you think? Will it soud right with the dual outlets behind the rear tires? The more I think about it the less I like it. Nevermind.
Alwaysworking
06-07-2008, 12:39 PM
you dont have to tail pipes that are 3inch off your donors?
if so then you just cut one to fit to the drivers side.
Trooperthorn
06-07-2008, 09:00 PM
I just ended the exhaust about a foot behind the case. That's all I'll do for now. If it is too loud, I will stick on one of my stock mufflers. May try to put on the body tomorrow, but I do not know how much time I will get after church and family stuff. I still need to fix up the delivery and return lines at the tank. I ran the hard lines from the engine back, though.
Alwaysworking
06-07-2008, 11:23 PM
as long as you didn't put an elbow that points down at the ground it wont be too bad, and if you need help i might be able too
Alwaysworking
06-16-2008, 12:40 AM
update?...
Trooperthorn
06-16-2008, 01:04 AM
Been too busy installing a turned down elbow to post. Actually, I finished up the tank and fixed up the tranny harness. Then, I put the body back on. Then, for grins, we hooked-up the fuel solenoid and battery cables and torched it off. There was no fuel in the tank, and no radiator, and no intercooler, but we just ran the fuel out of the filter. It was cool. I have had this engine for over a year, even drove from Salem, Oregon to Reno and back in about 32 hours with just me and the dog to get the donor, but this was the first time I heard it run. Waiting for the video. Hint, Hint, poke, poke.
Thanks to Alwaysworking for his help the other night.
Check the cummins ramcharger blog in my sig for updated pics and details.
Trooperthorn
06-17-2008, 12:57 AM
27 seconds of joy! Thanks Always.
http://www.youtube.com/watch?v=2xIjts5cPuw
I'm the big guy standing by the starter.
Trooper.
Alwaysworking
06-17-2008, 01:53 AM
here is the first try
http://www.youtube.com/watch?v=vSZhcykygkQ
farmer0_1
06-17-2008, 02:55 AM
wish i wasn't knee deep in work on my little farm would like to see that one for myself. great job guys.
Trooperthorn
06-17-2008, 10:21 AM
you sound like a frog in a flood. kneedeep, kneedeep.[laugh]
farmer0_1
06-17-2008, 06:00 PM
with you doing all this trailbreaking and letting us in on the fixes along the way it should make my swap go way easy. still going to break away for a little road trip down your way.
Trooperthorn
06-18-2008, 01:06 AM
Thanks. I'm glad we cancelled the drum roll.[dummy]
Alwaysworking
06-18-2008, 01:08 AM
that was a good one, i bet if it could have made a rotation it would have started.
Trooperthorn
06-18-2008, 01:17 AM
I found out about this rust when I sucked a couple of inches of silt out of the cowel area. There are more extensive pics on my blog. This is a shot of the inside with the dash removed, above the fuel petal.
http://bp2.blogger.com/_1LEW_qppPEQ/SFiZ__gZlcI/AAAAAAAAAd4/Lp6k1-0wkFo/s400/IMG00075.jpg
I am almost done cutting the rust out. Tomorrow I will cut similar pieces out of a partial cab from one of my donors. Getting behind the column support/brake pedal hanger is the tricky part.
http://bp2.blogger.com/_1LEW_qppPEQ/SFiabx1VkGI/AAAAAAAAAeY/GzFqzbWSNyI/s400/IMG00080.jpg
This shot is in the cowel looking behind the culumn/pedal box.
http://bp0.blogger.com/_1LEW_qppPEQ/SFiacIRm5PI/AAAAAAAAAeg/Ff-wK4doRaI/s400/IMG00082.jpg
Trooperthorn
06-19-2008, 01:51 AM
I got the rest of the rust out today and fashioned a patch panel out of what was left of my other cab. It is not welded yet in the pic, but I do have it welded about half way now. I will finish it up tomorrow and get some POR 15on it.http://bp0.blogger.com/_1LEW_qppPEQ/SFn6cSEoI0I/AAAAAAAAAfA/1vFuoqYWC8M/s400/IMG00088.jpg
Alwaysworking
06-19-2008, 01:58 AM
if you remove the paint first it welds better
Trooperthorn
06-19-2008, 11:54 AM
Yeah, I did that, I just was not thorough in some of the hard to reach areas.
farmer0_1
06-19-2008, 02:25 PM
nice patch , won't even see it after some paint work.
Alwaysworking
06-19-2008, 09:48 PM
thinking about it, you should have just put the whole firewall in out of the red cab in.
Trooperthorn
06-19-2008, 11:33 PM
I thought about cutting it out big and overlapping it and spot-welding it in place, then goop the whole mess up with body pucky, but I thought this would be good general body patch practice. The fact that nobody will see it ia an added bonus.:rolleyes:
Its a toss-up. The red firewall was crumpled a bit on the pass. side. I would have had to flatten it. Then, when I was done, I would have to rely on my meager welding skills because it would have been structural rather than merely waterproof.
Trooperthorn
06-24-2008, 01:32 AM
Updated the ramcharger blog. www.cumminsramchrger.blogspot.com (http://www.cumminsramchrger.blogspot.com)
Ditched the patch job and went for the whole firewally enchilada. http://bp0.blogger.com/_1LEW_qppPEQ/SGCLASb5Z-I/AAAAAAAAAgQ/9zRkk6SUm1k/s400/IMG00119.jpg
The donor
http://bp2.blogger.com/_1LEW_qppPEQ/SGCMutEm8VI/AAAAAAAAAgw/HElDxzSh15w/s400/IMG00099.jpg
Almost ready to weld.
http://bp3.blogger.com/_1LEW_qppPEQ/SGCLAlSXipI/AAAAAAAAAgY/UHn-cyY5YeI/s400/IMG00117.jpg
Alwaysworking
06-24-2008, 01:36 AM
still have to sand off the paint but other than that and about your nose i think you need to pull it all apart so you can fit your intercooler
Trooperthorn
06-24-2008, 01:59 AM
Yeah the nose is mostly apart now, just need to pull the core and inner fenders. Here is a pic of the sad looking donor.
http://bp2.blogger.com/_1LEW_qppPEQ/SGCMukBq8WI/AAAAAAAAAg4/zgewJzrvCUs/s400/IMG00098.jpg
farmer0_1
06-24-2008, 09:24 AM
here i thought making a couple of cowl crack replacement panels were going to be a pain. wow. after i get my hay up i going to come down that way to survey the carnage. just think how nice it will be to have a solid ride, instead of something with rust issues. keep your chin up and don't loose confidence your doing the right thing.
Trooperthorn
07-07-2008, 02:10 AM
Lots done on this thing lately. Got the new firewall in.
http://bp2.blogger.com/_1LEW_qppPEQ/SGcShN3hc2I/AAAAAAAAAh4/x4gf6teFFAE/s400/IMG00129.jpg
Installed the heater box.
http://bp0.blogger.com/_1LEW_qppPEQ/SGcX5HLf8tI/AAAAAAAAAio/vmR_r8Gyq6o/s400/IMG00134.jpg
Installet the core support, radiator, intercooler, and tranny cooler. If you want to see how all this was done with an non-intercooled non-ctd core support, check out the blog in my sig. Lots of pictures and measurements.
http://bp0.blogger.com/_1LEW_qppPEQ/SG3A0nbbpMI/AAAAAAAAAso/VbDJ6n2QksM/s400/IMG00255.jpg
Got the dash mostly in.
http://bp2.blogger.com/_1LEW_qppPEQ/SHG-uce2Q6I/AAAAAAAAAvA/ooutFsm2UHE/s400/IMG00274.jpg
Steering hook-up is complete.
http://bp0.blogger.com/_1LEW_qppPEQ/SHGsrLadUHI/AAAAAAAAAuI/ms01U_HVEWA/s400/IMG00287.jpg
This was another head scratcher, but if you are doing the newer column and the older steering box, I have it figured out in the blog.
Getting closer all the time. Hope to drive it while it is still sunny.
Trooperthorn
07-07-2008, 02:14 AM
Don't wait too long to survey the carnage or you might find an empty shop. (except for the crewcab project and a possible 2wd 4-door-extended-cab ctd dually I am thinking about for my p-pump truck.[laugh])
farmer0_1
07-07-2008, 06:04 PM
thanks for the invite want to stop by during the week sometime if we can make it work of coarse alwaysworking needs to chime in . in the last dozen days made alot of hay with the big push behind me. just got to catch up loose ends and sell some hay now.
Alwaysworking
07-08-2008, 12:41 AM
just let know i dont live too far away, but this work stuff might get in the way, i just hate it when that happens
Trooperthorn
08-11-2008, 12:25 AM
Haven't posted an update in a while. Been having too much fun driving it.
http://www.youtube.com/watch?v=Ex4oujyBUts
Kansascrewcab76
08-12-2008, 02:17 PM
Awesome!
Very nice to see a pop top CTD rolling on the coal.
Trooperthorn
12-06-2008, 08:25 PM
I was looking through this and realized I never posted any finished (for now) pics.
http://i335.photobucket.com/albums/m477/quietmanthorn/DSC02081.jpg
http://i335.photobucket.com/albums/m477/quietmanthorn/DSC02080.jpg
http://i335.photobucket.com/albums/m477/quietmanthorn/DSC02087.jpg
Alwaysworking
12-07-2008, 12:25 AM
what about with the top on?
Trooperthorn
12-07-2008, 12:43 AM
Gotta be home in the daylight.[laugh]
Alwaysworking
12-07-2008, 12:48 AM
i know how that is
