Cruse control quits.
Old 10-26-2009, 05:34 PM
01trailerpuller's Avatar
I have a 2001 4x4. Every so often my cruse control will quit and I can not turn it back on or it will not turn on at all. I am throwing P1596 speed control switch always high code with the key test. Has anyone had this problem? If so, how do you correct these problems? Also if I let it sit for a few hours and hit the on button as soon as I start it will work.
Old 10-27-2009, 10:23 AM
rebal's Avatar
mine will do that if I have my engine brake on when i try to use CC.
it will reset when i restart the engine
Old 10-27-2009, 07:07 PM
sloth's Avatar
Mine does that but it throws the apps low voltage code (forget the number) but that's cause my apps is goin out
Old 10-27-2009, 07:27 PM
how do you fix the apps problem if that is my problem?
Old 10-28-2009, 05:46 AM
sloth's Avatar
Well it may not be your apps. But if it is then you have to replace it. Do a search on here for timbo apps. Lots of good info
oldblues
08-04-2007 11:17 PM
Evertight
02-19-2007 11:57 PM
alborada
07-22-2006 12:20 AM
xyzer
04-23-2005 01:06 AM
Quick Reply: Cruse control quits.
