Cruse control problem
Old 06-19-2011, 01:53 PM
jpajax's Avatar
Well I guess I spoke to soon that had no problem. It just started that when I try to turn the cruse on the light on dash will come on then suddenly go off and cruse control doesn't work. Any suggestion on what to check?
Old 06-19-2011, 04:01 PM
Spooler's Avatar
Vaccum lines from the vaccum pump by the passenger side battery. The line will run to the dashpot under the drivers side battery. If you have had a leak for a while you may have burned up your pump.
Old 06-19-2011, 04:03 PM
brightrevenue's Avatar
I would have the PCM checked out. My PCM has a problem & I'm waiting for a new one. It's only been 9 months, but Chrysler doesn't really care. The other thing you may want to check is the speedometer connection.
Old 06-19-2011, 06:52 PM
jpajax's Avatar
Pump working ok pulled the line off and it came on plug it up built up vacuum went off. Could not find a fuse marked cruse control but I guess if the light comes on would the fuse be bad. Is there a wire that goes to the back of speedometer?
oldblues
08-04-2007 11:17 PM
Evertight
02-19-2007 11:57 PM
alborada
07-22-2006 12:20 AM
xyzer
04-23-2005 01:06 AM
Quick Reply: Cruse control problem
