Cruise Control
Old 02-18-2004, 09:37 AM
Gman77's Avatar
Cruise Control
Cruise decided to quit the other day. The On/Off switch will sometimes illuminate the light after pressing it a few times. The same for turning off the light, press a few times and it may go out. When the light does eventually come on, it will not set a speed. I have check the switches according to manual, and replaced clockspring.
If it was a solenoid or vacuum problem, should the Cruise light still function normally?
Any help before it goes to the shop is appreciated.
Old 02-18-2004, 09:50 AM
Commatoze's Avatar
Have you pulled the driver's side battery and looked underneath it? Acid sometimes leaks from the battery and drips onto the criuse component directly below destroying it.
Old 02-18-2004, 09:56 AM
Gman77's Avatar
Would the Cruise light still not be able to be turned on though?
Old 02-18-2004, 12:48 PM
TJinTX's Avatar
Mine did this. It turned out that the wires in the steering column were too short, and using the steering wheel tilt broke the wires. Sometimes the cruise light would come on if the wheel was in the "up" position.
Not too difficult to fix, but still a pain.
Hope this helps.
Firstgenfanatic
11-08-2009 04:05 PM
Landini1
03-06-2009 07:01 PM
trophystock
07-06-2006 06:28 PM
sam
03-31-2003 09:04 PM
TexasDiesel
12-27-2002 10:47 AM
Quick Reply: Cruise Control
