cruise control
Old 11-17-2011, 10:11 PM
Onemoparnut's Avatar
cruise control
Where is the cruise control servo located under the hood. I looked today quickly in the rain and I didn't see it. Truck is a 97 3500.
Old 11-17-2011, 10:22 PM
Pickin on the wrong admin...
Diesel Dave2's Avatar
I know on my truck...All the cruise control stuff is right under the drivers side battery box...What problems do you have with your cruise??
Old 11-17-2011, 10:45 PM
The cruise won't work at all. The light comes on in the cruise switch bar but it won't set. I had my scanner hooked up to it today and it sets a Target speed and everything but when you let off the throttle it won't maintain your speed.
Old 11-17-2011, 10:54 PM
Maybe try this...There is a switch that goes out of adjustment at the brake pedal....While on the highway pull up on the brake pedal and hold it there...Then engage the cruise..Its a quick test if the switch is out of adjustment...On my truck it always goes out
Old 11-17-2011, 11:09 PM
I will give that a try but I don't think that is the issue because I can see on the scanner if the brake is depressed or not. Thanks for the help I will post what I find out.
Old 11-18-2011, 07:21 AM
98ramtough's Avatar
You might check the hard plastic vacuum hose. When I was changing shocks out last year I bumped it and it cracked in half. Then I didn't have cruise control. I taped it back together with electrical tape and has been good for a year. I should replace the hose, but I had other things to do.....
Old 11-18-2011, 07:34 AM
Thanks I will check that out.
Old 11-18-2011, 08:03 AM
Andy505's Avatar
Mine had split in half too, but I just replaced the whole line. Works great now.
Old 11-18-2011, 07:41 PM
ET RAM's Avatar
I went thru all the troubleshooting regarding my inop cruise control. My cruise light on the steering wheel switch did work but cruise would not set. I then checked the brake switch. That tested good. The vacuum was next but a test with a vacuum gauge eliminated that as a problem. Vacuum was good.
I then did the electrical test on the servo. The servo failed. I purchased a new servo and wiring harness and cruise is good to go again.
The servo lives in a very bad location. Battery acid works its way to the servo and fails the vacuum line and the servo itself. My servo was in pretty bad shape.
New servo was my fix.
Old 11-20-2011, 01:19 AM
plow's Avatar
The trouble with mine was oil from vacuum pump had got past the check valve at the vacuum pump and had melted my vac lines. It affected my climate control,cruise control,and my 4wheel drive would take forever to engage and disengage. There was a recall on the 94-96
Old 11-20-2011, 08:19 AM
I found the problem the line is all cracked and there is a hole in the servo from a bad battery I guess when the po had it.
Old 09-26-2013, 11:09 AM
Robert Brown's Avatar
I too am having problems with the cruise control. It engages for a few seconds then disengages. The dealer has told me the servo needs to be replaced, but then they said it is related to a bad instrument cluster. Clearly, I can't trust the dealer. Any help other than what has been listed?
Firstgenfanatic
11-08-2009 04:05 PM
Landini1
03-06-2009 07:01 PM
trophystock
07-06-2006 06:28 PM
sam
03-31-2003 09:04 PM
TexasDiesel
12-27-2002 10:47 AM
Quick Reply: cruise control
