Cruise control / Heater vent selector
Old 12-31-2008, 05:19 AM
daddy mopar's Avatar
I just replaced my VP44 and when I took my truck for a test drive I found two more problems
My cruise control will turn on but will not actuate.
My heater works but wont change from the defroster position regardless of my choice!
I cant find fuses for either of these systems, does anybody have any helpful information?
Old 12-31-2008, 05:28 AM
derf464's Avatar
My guess is that while you were working on your VP you pulled loose your vacuum line from your vac pump. The reason I know this is because I did the same thing. Those two poblems both run off the vac pump. Should be a stiff plastic tube which plugs into a rubber tube at the pump.
Old 12-31-2008, 09:18 AM
oudive's Avatar
Yep, second the vacuum line. Just swapped my heater core and I had accidently messed up a vac line.....only defrost and nothing else. Quick fix, just replug and play....LOL. Good luck with it.
Old 12-31-2008, 09:29 AM
johnh's Avatar
same here ,only industrial injection did it..... easy fix
Old 12-31-2008, 09:38 AM
Fueling around's Avatar
The hard plastic line can be brittle. Mine broke in a couple places. Rubber vacuum line from autoparts store spliced the pieces together.
Old 12-31-2008, 04:23 PM
nickg's Avatar
Yep I did the exact same thing!!
Old 12-31-2008, 06:13 PM
Kiff's Avatar
I have the same issue but with a p-pump truck, where would I find the vac line for that?
Old 12-31-2008, 06:52 PM
Stamey's Avatar
Same place. The vacuum pump is in front of the PS pump. There is a port on the side of it. Just trace the hose from there to the places it goes, e.g. cruise control actuator, under the left battery, and the HVAC plumbing, which enters the firewall directly above the exhaust manifold. If you have a 96 or older truck, you also have a brake booster and a vacuum sensor for the bakes on the left fender well.
Chris
MrKen
02-02-2017 04:39 PM
leeboy
02-21-2015 12:15 PM
#2isgreen
12-12-2010 10:22 PM
EverydayDiesel
06-22-2007 08:11 AM
fordsux8269
02-07-2005 08:56 PM
Quick Reply: Cruise control / Heater vent selector
