cross over steering, is it worth it.
im in the process of fixing my truck steering. at the moment ive done everything i can thing of to tighten up the steering in my truck. i have put on duel stablizers, borgensin shaft, and adjustible tie rod. im going to be replaceing the steering box shortly as well. and i keep hearing about this crossover steering. and i was wondering if any of uses are running this setup? and if so how did you like it?
I haven't done it yet as I don't have enough lift but plan to. Everyone I've talked to loves it. You should have enough room with your 6" but it might be close.
I know the ORD kit is a bit pricey, But unless you have access to a nice tube bender, I would go with there kit. Their steering bar has a bend in it now to clear the crossmember better and it puts it on almost no angle. Which you want. I definatly reccomend it running that 6" lift.
you really want to Beef up the frontend do like I did put crossover steering dual stablizer's and Dual front shock's
http://www.slide.com/r/5Fc1swrk7z_CDNSNofSr7eS2GRlJrssA worked great going to do same on my new build also
1985cucv
07-19-2009 02:16 AM
CrashCade
18
06-19-2007 04:19 PM
