crank sensor to tight?
Is it possible to get your crank sensor in too tight? I just replaced mine and heard alot of clicking from the crank case. Now the crank sensor is bad again. Someone had once told me not to tighten it to much or it would ruin it. My buddy had the sensor in before I got home so I don't know how tight it was put in. Any input would be great. Thanks BP
I believe your problem is the tone ring that the position sensor monitors. From what I understand this ring is bolted the crank and if it comes loose it will hit the position sensor. You need to drop the pan and either tighten or replace it.
Originally Posted by mrschendel
Tone ring is easy. removing the oil pan is a pain to remove.
If it's easy I would LOVE to see you do one. I've done two and they were both a major pain in the rear. One half comes off easy, but the other piece reminded me of those "chinese" puzzles where you had to have everything aligned just so (including the moon and stars) before it would somehow move into position.
sounds to me like I better just take it somewhere and have it done. I'm a backyard mechanic myself, can get most of the simple stuff done, but leave the major stuff to the pros.
Remove bearing cap between 5 and 6, remove # 6 rod and push to the head. Rotate crank until the small piece of the ring is at the lowest point remove the bolts. small ring comes out, rotate the large piece with the open end upward, Remove the ring.....
Originally Posted by J BODY
...well imagine doing that without removing the #6 rod. I'll keep that in mind if there is a "next time". It was funny though....both times I was able to manipulate the big piece out fairly easy....but found it a challenge to get the new one in. One I did the big section had come loose. The other was on a brand new long block that had a tooth broken off it. Engine ran like crap and I won't go into details how long it took to find that one!
92smokin blacky
02-28-2011 02:36 PM
aaronedwards82
01-14-2007 09:07 AM
PaulDaisy
12-02-2006 12:36 PM
