CP3 mod ?...again
Old 09-04-2007, 09:23 AM
goodeyesniper75's Avatar
CP3 mod ?...again
Today i should be getting my spare FCA and was wondering....what if i just did the FCA first then finished the other part another time? any adverse effects?
Old 09-04-2007, 09:28 AM
DTR 1st Sergeant
soulezoo's Avatar
None whatsoever! I've been running like that now for a couple of weeks. How much did the FCA run ya?
Old 09-04-2007, 09:46 AM
like $90 plus shipping...how do you feel about the mod? did you notice anything?
Old 09-04-2007, 10:05 AM
tesla440's Avatar
I reworked my FCA only. No problems. The low end power is great. Boost come on alot earlier & quicker. I also noticed my boost sits at 7psi at 70mph where before it would be 3-5psi. I'm checking to see if this help my mpgs any. If not it'll be up for sale.
Old 09-04-2007, 10:11 AM
sounds good...i just took my spare one apart and i will be cutting it up tonight hopefully.
Old 09-04-2007, 10:25 AM
DTR 1st Sergeant
soulezoo's Avatar
There is really nothing I could measure (like comparing before/after on a dyno) to tell me anything definitive. For most regular driving I saw no difference at all. The only difference I saw was on WOT runs. More smoke, faster spool, higher spool and power seemed to stay on longer meaning I was probably draining the rails before. This is all in conjunction with the lift pump upgrade too.
Old 09-04-2007, 10:26 AM
DTR 1st Sergeant
soulezoo's Avatar
BTW-- + shipping? You didn't get it from the dealier then? Where did you source it?
Old 09-04-2007, 10:33 AM
i went on the cummins site and looked up parts dealers. just gave them my part # and it was here the next day.
Old 09-04-2007, 10:34 AM
well i just cut my FCA took about 2 mins on each side. what did you guys use to de-bur?
Old 09-04-2007, 10:43 AM
DTR 1st Sergeant
soulezoo's Avatar
on the inside I used finest burr tool for the dremel I could get. On outside I used polishing wheel and compound and cleaned thoroughly afterward.
Old 09-04-2007, 11:08 AM
82NDSNPR's Avatar
fca????? need info please have no clue what that part is
Old 09-04-2007, 11:18 AM
its where the fuel comes into the cp3...by enlarging it and one other thing its basically a DIY stage 1 mod.
Old 09-04-2007, 11:32 AM
omaharam's Avatar
I wouldn't term that as such. My stage 1 cp3 is much more extensive than elarging the passages of the fca.
Also, I was told just doing the fca gains very minimal. You need to modify the rotor housing to allow it to move enough fuel through the now modded fca.
Old 09-04-2007, 11:38 AM
yes.....your correct...
Old 09-04-2007, 12:39 PM
82NDSNPR's Avatar
k good to know i am going with a stage 3 cp3 so this does not need to be done in my case thanks for the info
Quick Reply: CP3 mod ?...again
