HOW could this have happened to my gauge??
Old 06-12-2011, 02:07 AM
wcbcruzer's Avatar
Ok, so I get back from my 9 day mission trip to find that my boost gauge needle is on the OPPOSITE side of the little stopper and won't budge. It was perfectly fine the day I left. Has anyone ever seen anything like this?? What could cause it to get stuck like that? I'm really baffled. It is possible that someone took my truck for a joyride while I was gone, in which case I would be .
Old 06-12-2011, 06:16 AM
chaikwa's Avatar
It broke.
You're welcome!
Old 06-13-2011, 07:11 AM
rockcrawler304's Avatar
Originally Posted by chaikwa
It broke.
You're welcome!
Mr. Obvious strikes again!
If it wasn't that way when you left, somebody drove it when the failure occurred. Just not sure how it would end up there except for what chaikwa pointed out.
Old 06-13-2011, 07:30 AM
Just a plain ole guy
1-2-3's Avatar
Don't those gauges seem to go a bit wild on a self test pattern when they power up? Probably did it then. Or it simply evolved into a vacuum gauge. Did you hear a big bang at any time?
Old 06-13-2011, 09:48 AM
wcbcruzer's Avatar
Turns out the heat melted the glue and broke a piece inside, causing it to go erratic. That's the only thing I can think of. Never seen anything like this. Guess it was just bad timing.
Old 06-13-2011, 12:50 PM
Lil Dog's Avatar
I was thinking, uh, get a 60# gauge.. LOL..
Old 06-13-2011, 01:07 PM
Top's Younger Twin
Scotty's Avatar
Melting is always a possibility. I suggest that you go big or...
LOL
When you replace it.
Old 06-13-2011, 02:38 PM
sdntive's Avatar
Did the same to mine, stock waste gate off, and letting the boost hit 30 to 35psi. Went to the 60psi gauge and have had no problems since
Old 06-17-2011, 03:39 AM
Jim Lane's Avatar
I have a 100 PSI test gauge just last week the same way. I went to use and the pointer was on the wrong side of the stop, I am sure I didn't put it away that way.
I popped off the dial face and set it on the correct side of the stop
It was also a Bourdon tube style gauge.
Jim
Old 06-17-2011, 10:15 AM
infidel's Avatar
I've had Bourdon tube type gauge needles end up on the wrong side of the pin when water in the tube freezes.
Sometimes they read correctly again when you lift the needle over the pin but most times not.
1972RedNeck
10-29-2013 06:55 PM
Dodgezilla
02-05-2008 02:06 PM
duallydave
11-04-2005 08:14 AM
cumminsdriver635
05-01-2004 10:41 AM
12-29-2002 09:43 PM
Quick Reply: HOW could this have happened to my gauge??
