Cost of water pump replacement?
Old 09-10-2011, 09:47 PM
electrifried's Avatar
At a jobsite for a month, Let a good friend use the 2000 2500 to go to the hotel so he didnt need to try to park his 18wheeler. Got a call that there was a green drip and puddle under it. I had no time to deal with it and the next stop on this tour was about 700 miles away, so I called a farmer friend that was a ASE mechanic to fix it. It took a while to get it to repeat the leak but the water pump was the cause. He put a NAPA lifetime in it? He will not give me a bill for what he has done. I want to pay my bills!
Whats a FAIR price for this?
Old 09-10-2011, 10:10 PM
Silver R/T's Avatar
My idiot boss paid $460 for shop to do it and he said "that was great price!"
As far as pump it's like $50 at most parts stores
A good mechanic can do it in under an hour
Old 09-13-2011, 09:38 PM
I thought I would see a few more replies to this.
Old 09-13-2011, 10:45 PM
rebal's Avatar
$150 bucks is a fair price for a 2nd gen.
Old 09-13-2011, 11:17 PM
crackcorn's Avatar
Pump is $50 at parts store. Just did mine and took me two hours, there was a one hour learning curve. An experienced mechanic could do it in less then an hour I'm sure. You might consider giving him a 150$ gift certificate to a nice restaurant to say thank you. That way he's not offended if it cost a bit more or less for him to do. Then he can share with his wife or girlfriend. Just food for thought.
Old 09-14-2011, 10:22 PM
He is just closing up the buliding of a new shop. I was thinking of giving him a couple of "high bay t-8 flourecent" fixtures for that project in trade.
Thanks for the help
Old 09-15-2011, 07:55 AM
j-fox's Avatar
15 minutes will change the water pump on a Cummins.
Old 09-17-2011, 11:19 PM
totalloser's Avatar
+1
1/2" breaker bar on tensioner to loosen belt, slip it off, and two bolts for the water pump. No gasket it uses an o-ring so cleanup is quick. Install pump, put belt back on and top coolant.
I'd shoot him $50 for the hassle factor he saved, personally. Install plus diagnosis. If he doesn't want to take money, a $50 gift might go nicely with the thanks and handshake?
Old 09-20-2011, 11:35 PM
dkenny's Avatar
wow..15 minutes..
I haven't had to do this on mine yet..
but on other Dodge, gasser 318, it took longer than 15 minutes.
what about buying a good dinner with drinks at place of his choosing?
-dkenny
Old 09-23-2011, 10:16 PM
nickg's Avatar
water pump is held on with 2 bolts, could not be any simpler, takes longer for the coolant to drain, than to replace the pump. honestly 1 hour is more than enough time,
I bet he would appreciate a good dinner and drinks.... pay it forward I say
Old 09-26-2011, 09:53 AM
Crallscars's Avatar
I did mine a few months ago, if it take your mechanic more than 15 minutes, you are paying for his texting, coffee break and time at the lunch wagon.
Dodge/Cummins couldn't have made it easier.
I'd buy your friend a $50 gift card to Outbacks
Old 09-26-2011, 08:35 PM
gunnie's Avatar
i thoughT-8 lights were a great trade, anyone with a decent shop can always use good lighting
Old 08-18-2015, 01:12 PM
Eddie Sambrano's Avatar
need help
Is it easy for someone who's mechanically inclined like myself to install a water pump on a Dodge Ram truck 3500 diesel?
Old 08-18-2015, 05:40 PM
patdaly's Avatar
About the simplest water pump install possible.
Old 08-19-2015, 08:31 AM
Crallscars's Avatar
If you can change the fan belt and add water to the radiator, you're qualified to change the water pump.
I say that because you have to loosen the fan belt first, then there are 2 small bolts that holds the pump in place. The pump uses an "O" ring so there is no old gasket to clean off. Install the pump, install & tighten the 2 bolts, put the belt on, refill radiator.
roughstock
06-18-2009 09:18 AM
carri56
16
12-12-2008 08:35 PM
Banzai Bob
07-17-2007 11:08 PM
AggiePhil
17
10-19-2006 06:18 PM
451Mopar
04-30-2005 07:36 PM
Quick Reply: Cost of water pump replacement?
