?? Coolant Zerex G-05 ??
Old 10-14-2005, 11:42 AM
HOUTEX's Avatar
Did some searching on coolant questions,, it seems the common answer
for a coolant to purchase at auto parts store or Wally World is
ZEREX G-05. ANY OTHER SUGGESTIONS BEFORE I PURCHASE ??
ANY NEW INFO ??
I will be replacing about 2 gallons, mixing with the origianal stuff
after filtering.
Doing this because I found sediment/particulate in lower rad hose.
Not sure what it is but I don't think I want it in my system.
Maybe I should replace all coolant, not just filter the old ??
Old 10-14-2005, 12:12 PM
Berak's Avatar
That is the only HOAT type coolant I could find that was easy to purchase.
Old 10-14-2005, 12:39 PM
smiller's Avatar
I believe that the Zerex G-05 formulation is the factory fill, and is approved by DC. I don't think you could go wrong by using it, in fact I don't think I would use anything else.
Old 10-14-2005, 04:08 PM
Marine's Avatar
Drain, flush, and refill entire system with new coolant. Additives in the coolant wear out. It is better to change it all.
I replaced the coolant with Shell Rotella ELC 60/40 predilute. It seems like a great coolant, and I just have to add a rejuvenator once per year I believe.
shonne
26
06-19-2010 09:25 AM
Mark Hodowanec
08-20-2009 07:26 PM
LFD2037
06-28-2008 11:28 PM
expressfish
02-24-2007 08:36 AM
Hairy1
11-29-2004 04:26 PM
Quick Reply: ?? Coolant Zerex G-05 ??
