Connector tubes
Old 09-20-2005, 10:32 AM
Piker's Avatar
Connector tubes
If my rig's injectors on my 98.5 24v have all been removed by a dealer for cleaning when I got some bad fuel, did they put the later connector tubes back in that do not distort, so if I get bigger injectors I won't have to get new connector tubes? Thanks
Old 09-21-2005, 06:01 AM
CTD NUT's Avatar
If your 98.5 24v engine serial # on the CPL plate is before #56462592 you will need the injector tubes.......if it is after that you already have the newer style tubes that don't need to be replaced......as for the dealer replacing the tubes when the injectors were removed - who knows......even if your motor did need them, I wouldn't put much faith in them that they know if the tubes were required or not........if you needed the newer style injector tube or not, I would bet that they were not changed.
Old 09-21-2005, 07:17 AM
Piker's Avatar
ok thank you. How do you like the 275 injectors? I have a van aaken, and would like to get them for towing. My injectors may be dumping more fuel than they should because it idles around 340 degrees, and the best mileage I can get is 15 babying it. The gas station that I used to buy fuel at let a bunch of water run into their tank in the winter, so I was the lucky one that got it. The dealer told me they cleaned the injectors, but it could have damaged one.
Old 09-21-2005, 07:57 AM
darrenG's Avatar
Did you just make that number up or do you have it memorized?
Old 09-21-2005, 07:59 AM
CTD NUT's Avatar
Ah, Come awn!! Give me a little credit!! FWIW, I did have to go look the serial # up......Sheesh!
Old 09-21-2005, 08:07 AM
CTD NUT's Avatar
I really do like the RV275's.......you get a good bang for the buck. They are not smokey and actually have improved the running quality of the engine. I would have liked to have some Mach 1.6's but they were out of my price range at the moment. FWIW, after installing the 275's, I'm quite convinced that injectors can wear out and cause higher egt, worse mileage and poor running quality. The change is so gradual over time that you never notice - until you drop new sticks in and can't believe how much new injectors help. I think this would only apply to CTD's with at least 150k + but who knows..... a lack of lubrication in the injectors could cause some accelerated wear.
Old 09-23-2005, 10:09 PM
Ruralmedic's Avatar
What's the deal with the early injector tube?
I was ready to install RV275's today and noticed my ESN was prior to the one posted, so I went to Cummins and purchased new crossover tubes today.
I put the injectors in tonight, and when I pulled the old tubes out, they looked exactly the same as the new ones did, with most of the numbers stamped on them matching up. I went ahead and installed the new ones, along with the new injectors. I bought the truck used, so it is possible that they could have been changed by the previous owner(s).
Just finished the job, and have only driven the truck a few miles so far, but so far so good! I like! Now to train the right foot, that go pedal is fun!
Old 09-26-2005, 06:00 AM
CTD NUT's Avatar
The injector tubes on engines prior to serial #56462592 are supposed to be made out of a softer material that deforms slightly when the injectors are removed. Apparently, they deformed so frequently that it became common place to install the newer tubes on engines prior to this serial #.
Old 09-26-2005, 08:41 PM
Ruralmedic's Avatar
OK, thanks for the info!
Old 09-26-2005, 10:16 PM
J BODY's Avatar
...curious NUT, where did you get this info. I checked on some TSB's on 98-99's and found nothing on this subject. ???
Old 09-27-2005, 09:24 AM
CTD NUT's Avatar
I actually got this particular info from this board awhile back and it was confirmed by Cummins when I got the new tubes.....the old tube part # was superceded by a new part # that was indeed the original part # for the engines after #56462592.
Old 09-27-2005, 09:12 PM
J BODY's Avatar
.....and once again. I've learned something valuable here.
cumminsdriver635
11-05-2006 08:26 PM
rockjeep73
13
10-24-2006 02:59 PM
Barefoot88
13
12-07-2005 08:36 PM
Cumminsdieselboy
01-23-2005 07:17 PM
More Power
01-10-2004 10:55 AM
Quick Reply: Connector tubes
