Condensation in light?
Old 02-12-2004, 09:03 PM
goldenears's Avatar
Was wondering what if anything can be done with a condensation problem beginning in my right front park/running light assembly? I checked for cracked or split glass and there is no obvious signs of leakage. The back area is dry and secure. Is there any magick solution to this condition?
Old 02-12-2004, 09:07 PM
DF5152's Avatar
drill a small hole in the bottom or some place where water can't get in. has worked in the past
Old 02-12-2004, 09:55 PM
y-knot's Avatar
I second what he said, I had the same problem with both front lights, tried everything and had no luck. Finaly drilled the holes just to let the water escape and walaa, no more problems.
Old 02-12-2004, 10:03 PM
goldenears's Avatar
thats a good idea. i dont have major water sloshing around...just a fine mist building up on the lens, but it makes sense that if i drill a small hole the air can circulate around and dry things out.
Thanks guys
Old 02-12-2004, 10:33 PM
LHartman's Avatar
My drivers side headlight has condensation in it. I pulled the assembly out, dumped the one inch of water out and pressurized it. I couldn't find a leak one, so I'm not sure how the water is getting in. I'll have to try drilling a hole. I've lost two bulbs to it so far.
Loren
Old 02-13-2004, 06:56 AM
bulthisl's Avatar
I drilled about 4~5 1/8 in. holes on the bottom just behind the seam.
This way it will drain with the truck leaning right or left.
And lets the air circulate.
Worked like a charm.
: Eddie :
Old 02-13-2004, 08:45 AM
y-knot's Avatar
When I was having my water problems,everyone I talked to said there must be a air leak. I to looked and could not find anything wrong, got peeved off and ordered all new lights up front. Thinking with new lamp housings I will fix the problem, Wrong I had even more water. Drilled the holes and now it's fine, I and everyone else was back ward in our thinking.
cad14man
12-31-2007 01:02 PM
HappyGA
11-27-2006 07:45 PM
duner
03-19-2005 04:31 PM
97Dually
13
06-14-2003 12:21 PM
ekim440
01-02-2003 09:16 PM
Quick Reply: Condensation in light?
