Compressor O-ring?
Old Aug 8, 2005 | 01:06 PM
rockjeep73's Avatar
Compressor O-ring?
I rebuilt my turbo over the weekend, HX35/40, and when I disassembled it there was no o-ring between the compressor housing and the center section. The rebuild kit came with an o-ring for this but the problem was that the housing wouldnt seat far enough on the center section to allow the large snap ring to fall into place. My question, is the o-ring necessary? or is it only used on certain turbos? As of now the turbo was put back together without the o-ring and works fine.
Old Aug 8, 2005 | 03:12 PM
The o-ring seals the compressor housing. You have a boost leak now. If the old o-ring isn't torn try using it, it is compressed and will fit easier.
Old Aug 8, 2005 | 03:48 PM
rockjeep73's Avatar
there wasnt an o-ring when I took it apart. the housing fits nice and tight without it so there cant be too much of a leak, i would think.
Old Aug 8, 2005 | 03:58 PM
OK. I would suggest calling HTT and asking their opinion. They've taken apart a few more turbos than I have.
Old Aug 8, 2005 | 06:19 PM
59FORD's Avatar
My 95 HX35 does not have an o-ring. My old H1C does have an o-ring.
The HX35 does not leak, at least I don't hear anything or see a pressure loss.
Old Aug 8, 2005 | 08:20 PM
rockjeep73's Avatar
Thanks, i will call HTT tomorrow and make sure.
WhoCares79
Jun 3, 2008 11:45 AM
Camarogenius
Jun 25, 2007 08:55 PM
HaulinBut
May 12, 2006 03:06 PM
JKM
Mar 8, 2006 03:23 AM
