compression
I thought it was 17.5:1, but I'm probably wrong. You don't want to go changing the ratio, much better just to leave it where it is. If you want your engine to last anyway. I went down this road a few months ago, (search my threads) but was advised I was
. It's understandable, our ratio is pretty high for a 20-odd year old truck as it is.
From: A 5th dimension, beyond that which is known to man.
lower compression equals less cylinder pressure. that means you have more room to add boost and a greater volume of cool air to the cylinder. more cool air will let you add more fuel, which of course means more power. lower compression will make your truck harder to start and lose some low end power.
there are people out there that are much smarter and could explain better but you never know if they will show up and post.
Ahh, I see. But... if the cylinder temp is lower, and you add more fuel, you're not going to burn all that fuel... or are you? Seems like kind of a waste if you're not harnessing all the calorific value of the fuel.
... is 'calorific' a word?
again, im no expert but...
im sure with enough rpm, timing and turbo you would be able to burn it. it will still kill your throttle response and low rpm torque.
i wouldnt run much more than a .020 gasket on the street. i think thats one less point of compression roughly.
There is a guy up here that is building a puller/street truck p pumper that has 15 to 1 ratio. Not sure how street friendly it will be. I would stay in the 16.5 to 1 ratio. Thats pretty much where some of the marine 6 b's run.
I wouldn't know!
