Component failure mileage.
I own a 1999 Dodge 2500 Cummins 4 X 4 with 5 speed maual transmission. It has approx. 200,000 miles on it. I am looking for experience of other Cummins owners concerning the anticipated mileage failure point for the following five components:
Starter
Alternator
Water Pump
Front Wheel Bearings
Air Conditioner Compressor
I anticipate having to take many long range trips in this truck in the coming months and am trying to head off problems on the road with needed replacements beforehand.
Thanks for your help.
Starter
Alternator
Water Pump
Starter: You should replace the starter contacts ASAP. http://www.fostertruck.com/dodge/default.htm See my pics. Easy job.
I would have the front end checked for ball joint replacement.
A fuel pressure guage is a MUST!
Ball joints at 57K
Track bar at 57K
LP at 93K
High pressure power steering line 99K
Starter at 109K
Vp44 at 125K
Hopefully I have covered all the expensive stuff, this truck will hopefully run 350K miles, so I haev many years to keep it on the road.
Track bar at 57K
LP at 93K
Starter at 109K
Vp44 at 125K
I'm at 80K. Here's my score card:
Ball joints: original
track bar: original (and minimal play I might add)
front wheel bearings: original
torque convertor: 1st at 26K right after I bought it, 2nd still going.
lift pump: original (still at 13psi plus and never drops below 9)
VP: replaced my first one last week. 80K
Injection pumps go whenever they want. I've seen them go 300K+, I've seen them go in less than 20.
IPDiesel
07-29-2015 09:57 PM
dodgetrucker75
03-17-2011 09:15 PM
ppsi
01-27-2004 12:54 PM
dodgedude361
12-28-2003 03:36 PM
