comp box
Old 04-08-2004, 07:12 AM
mooseman's Avatar
comp box
can ne one tell me why my truck cuts out on level 3-5 on my comp. i had 275 injectors installed ever seince then it cuts out and pops on higher rpm (anything above 2000). has anybody else had this problem. ive been told i am running out of fuel and need a biger pump. also get codes 253 and 257.
thanks, mooseman
Old 04-08-2004, 07:53 AM
Ryan's Avatar
Check to make sure that you have a good ground wire connection and Pimp Wire connection on the Comp.
Old 04-08-2004, 09:17 AM
dodgeram's Avatar
what's your fuel pressure
Old 04-08-2004, 05:09 PM
mooseman's Avatar
ive checked all connections. all seem to be good. my fp gauge wont be here for a couple days so i cant tell. just trying to get some ideas from you guys that may have had the same problem or might have any good ideas. sometimes i wished i had left the darn thing stock.
thanks mooseman
Old 04-10-2004, 10:09 PM
bama's Avatar
im not sure about the 257 code,,but the 253 code is...fuel injection pump valve open circuit..maybe someone else can chime in on the other code.....sounds like you have something going on with your pump
bwarning01
15
08-24-2007 09:19 PM
04ctd
10-05-2006 08:27 PM
flinn101
12-14-2005 09:43 PM
hellotbone
07-12-2003 12:58 AM
danlit
02-13-2003 10:53 AM
Quick Reply: comp box
