COMP and Smarty stack?
Old Jan 1, 2007 | 10:02 AM
Awall's Avatar
Can you stack an edge COMP with a Smarty?
Old Jan 1, 2007 | 10:05 AM
blackdiesel's Avatar
Registered
in short, yes. youll need to run the smarty on even numbered settings...
J Double's Avatar
Yeap..just run even number programs on the Smarty.
Old Jan 1, 2007 | 10:06 AM
duallydave's Avatar
Talking
ya keep the smarty on fueling only softwares and it will work great,try a search on this site,lots of reading from guys that have it
Old Jan 1, 2007 | 10:09 AM
Awall's Avatar
ok thanks... is that recommended over a TST PM3? because i was thinking id sell the COMP and get a TST... and also if i did throw that COMP on there ill probably need a bigger turbo right?
Old Jan 1, 2007 | 10:10 AM
RowJ's Avatar
Since you don't have the Comp yet, (according to your sig) I would seriously consider the TST PM3 instead. This will allow you to ues the Smarty timing, which I feel is superior to the Edge timing softwear. This is assuming your buying new.
The Smarty/Edge Comp combo is good.... just think the Smarty/TST combo is a notch above.
RJ
Old Jan 1, 2007 | 10:12 AM
Awall's Avatar
Its not in my sig because im trying to sell it to get the TST... I always heard the TST/Smarty stack was great and thats what im aiming for.. Also lookin to upgrade turbo.. which turbo is recommended for that TST/Smarty stack?
Old Jan 1, 2007 | 10:15 AM
RowJ's Avatar
Guess we were typing at the same time...above.
Turbo will depend on what HP level your aiming for??
Without injectors, your HX-35 could be made to work well with a 14 cm2 turbine housing and opening up the divider some, to wastegate all 6 cylinders.
To solve EGT problems with TST on #9 you will need an S300 type turbo, like the the PS62 from
Here
RJ
Old Jan 1, 2007 | 10:23 AM
Awall's Avatar
i want to get as much HP as possible without having to do head work, and also want a balance in a turbo that will keep EGTs down but still get good HP
Old Jan 1, 2007 | 10:36 AM
RowJ's Avatar
Your talking 450 HP to be safe... and NEVER run hard till engine is fully warmed up. Don't ask how I know that's important!
A Smarty/TST with 100 hp injectors (recommend Mach 1.6's) and a PS64 would put you right there and be a great set up, IMHO.
Weakest link at that point, would be your clutch.
RJ
Old Jan 1, 2007 | 12:44 PM
Registered
you can (or so ive herd) get more top end hp out of a DRAG comp. however i believe the tst smarty is more driveable....
Old Jan 1, 2007 | 02:07 PM
Awall's Avatar
So i could run that setup that you recommended rjohnson without having to get head work?
Old Jan 1, 2007 | 02:13 PM
Awall's Avatar
and im going to get a soutbend CON-FE if i get the TST and turbo
Old Jan 1, 2007 | 02:26 PM
n0ne's Avatar
i have to ask... Why is it important ?
Old Jan 1, 2007 | 03:36 PM
Awall's Avatar
nOne, do you like your COMP/Smarty setup and what are the +/- to it?
