Commander Rail Pressure?
Old 01-31-2008, 05:19 PM
Seelow's Avatar
I just installed a used commander with the fuel pressure kit and didnt get any directions with it. I hooked it all up as per there online instrutions but I'm not getting any rail pressure readings. It just says zero. Can some one tell me or show me a pic of what wire to tap for the railpressure. I tapped the center one on the rail pressure sensor with the green one in the harness but like i said I'm not getting any readings. Thanks for any help.
Old 02-01-2008, 04:54 AM
Seelow's Avatar
bump anyone?
Old 02-01-2008, 05:38 AM
qzilla's Avatar
It sounds like you have the right wire tapped and are using the righ wire.
Look and make certain that when you plugged the green wire into the tap that the actual spade is going into the tap.
The other thing is to make sure the tap actually broke the shielding on the wire you tapped.
From there make sure you have the correct vehicle selected in the setup menu.
If that does not work call tech support 888-842-572.
Old 02-01-2008, 06:45 AM
AlCorr's Avatar
I had the same problem and it was just as qzilla said.
"The other thing is to make sure the tap actually broke the shielding on the wire you tapped"
Works excellent now.
5.9Excursion
03-13-2008 10:56 AM
AlCorr
06-15-2007 06:36 PM
Luvnacumns
04-12-2007 10:34 PM
rjm022
12-14-2006 05:20 AM
Quick Reply: Commander Rail Pressure?
