Commander Fuel Pressure Kits are here!
Old 12-16-2008, 04:31 PM
qzilla's Avatar
Well, sort of!
We recieved a totally un-expected shipment of a bunch of transducers today. We were not really expecting them until sometime after the first of the year!
The bad news is that our wiring harnesses are not due here until next Tuesday or Wednesday.
So, long story short, our order forms should be up on the web by the end of the day. Once you order them we will call you back and give you a RMA# to put on your shipping package so it goes to the right deparment when it gets here. We should be able to turn these around the same day we recieve them.
Pricing and detail should be on the order form.
If we left anything out or if you have questions please let me know.
Right now we have a large amount of them but, no an unlimited supply! If you want one, the faster you get them to us the better.
Quad
Old 12-16-2008, 05:04 PM
D45
D45's Avatar
Are these different than the old styles that were failing?
What is different about these compared to the old units?
Old 12-16-2008, 05:31 PM
wyocat's Avatar
Will the work for the recon gauge?
Old 12-16-2008, 05:44 PM
qzilla's Avatar
These are drastically different as they are a pressure transducer and not an electical sending unit.
This is good but, it requires you send your Commander in here because we have to perform some minor hardware updates to make it work. The order form has some good info in it.
These transducers require you to supply them with power and ground as well so it does not matter where you install them. We have made the kit super nice and super simple to install once you get it back from us.
Old 12-16-2008, 05:46 PM
qzilla's Avatar
These are for the Commander and Adrenaline only. When we come up with something for the RP gauge I will let everyone know. It may not even be possible.
The Recons and RP gauges do not have the issues the Commander and Adrenalines have because they are 5v systems giving us a lot more resolution to work with. The Commander and Adrenalines are 3.3v systems and it compresses the maps severely.
Sure, there are some of the FP sending units that are just bad but, overall they are fine provided they get grounded and are not screwed into anodized fittings or in an area where they are not grounded such as in a FASS pump.
The problems are that with some vibration the needle inside the sending units move just a little and it cause he gauges to jump because they are more sensitive being at 3.3v.
If you have one not working you need to send it in so we can send a warranty replacement.
Old 12-16-2008, 06:00 PM
D45
D45's Avatar
What is the turn around time to get the Commanders re-programmed?
Old 12-16-2008, 08:35 PM
dieselfan's Avatar
Originally Posted by qzilla
Well, sort of!
Quad
edit, i didnt read all the posts.
Old 12-16-2008, 08:38 PM
dieselfan's Avatar
who do i need to talk to about warranty replacement?
Old 12-17-2008, 10:20 AM
qzilla's Avatar
Starting the 29th we will start turning them around. We will turn them around the same day we recieve them. There is more to it than a reprogram though!
The way Christmas falls puts a little kink in the system as we are close on Christmas Eve through the rest of the week.
Call tech support, just like normal. 888-842-6572
Old 12-18-2008, 07:43 AM
AlCorr's Avatar
Thanks for the update, UPS just picked mine up..
Old 12-30-2008, 11:01 AM
welndmn's Avatar
I hate to talk bad, but this to me means I am done.
I am a huge Quad fan, I bought the race chip, then added the commander, then the fuel pressure kit, then the X2 upgrade.
I have bought 4 sending units from Quad, each time 10$ each.
Now "the fix" is for me to spend another 45$ to hopfully have it fixed.
I understand nothing is free, but how much money do I have to throw at a product that never worked right from the start.
Old 12-30-2008, 07:02 PM
busta's Avatar
my thoughts also
I bought the adrenaline w/pulse paid extra for the fuel pressure sender then they never worked bought others senders after a couple of quads senders and now pay another $45 for something I all ready payed for once?
nice warranty pay and keep on paying
Old 12-30-2008, 07:17 PM
dodgediesel's Avatar
I do understand if you buy something with warranty, it should be warrantied but........ It's because you are paying $45.00 for a $100 sensor so really, do the math.... Autometer sells the same type of sensor for $120.00. The Quadzilla one's that were failing are around $25.00 so is really paying $45.00 a big deal when you spend thousands on diesel performance goodies?? Not taking any sides but my original Quadzilla $25.00 fuel pressure sensor has worked since day 1 and that was quite some time ago. I'm sure some won't like this post but it's just my .02....
Old 12-30-2008, 09:54 PM
busta's Avatar
well lets see i payed an extra $90 to begin with for the fp senders
bought a couple of my own after quads failed $36 a piece spent hours and hours on hold trying to find out about the new ones being told it was a warranty item only to be told when they finally think it is fixed pay more or we ain`t doing nothing
Old 12-30-2008, 10:57 PM
We have 5 truck here all with either the Recon or the Commander, not one of them have had a faulty sending unit??? I guess we were lucky or something??
Quick Reply: Commander Fuel Pressure Kits are here!
