command start question
Old Oct 20, 2009 | 07:03 PM
fast59's Avatar
Hi everyone,ok here is my issue.I bought a compustar command start alarm system and am having troubles.the remote start can operate off one of two ways,tach signal or charge voltage.So here is the problem i dont have a tach so i tried useing the voltage regulator wiring but it doesnt produce a quick enough signal for the remote start to reconize its running.So my theory was to put in a tach but after getting one today and reading over the instructions (its an autometer) i see it has two wires coming from the alternator sensing device and now i dont know if i can go that route.So who here has a command sart in their truck and what is it using for a signal wire to tell it the truck is running.
Old Oct 20, 2009 | 07:17 PM
Free89W350's Avatar
Is your truck a factory ic truck if so you should have a factory tach plug under the dash you may be able to grab the signal off of that. If it is a factory non ic truck you may be able to set something up with a magnet style tach pick up on the crank.
Old Oct 20, 2009 | 07:22 PM
fast59's Avatar
It is a factory intercooller truck and it doesnt have the crank sensor or wiring in the truck at all.All though i do have a complete harness with it from one of the wrecked diesels in my collection.
BILTIT
Oct 1, 2011 03:33 PM
robert78.5
Feb 2, 2010 10:16 PM
JJK98CTD
Feb 7, 2009 12:23 PM
