will this combo work?
Old 06-03-2009, 10:30 AM
CaledoniaOutlaw's Avatar
Will I be able to keep my stock turbo if my truck has a , quad adrl , mach 4s , cold air intake and 4 inch exhuast ? thanks Dan
Old 06-03-2009, 10:55 AM
BigTXDually's Avatar
Ya it will last as long as it stays parked. Seriously you need a turbo for that setup.
Old 06-03-2009, 11:21 AM
thats what I figured , any suggestions on which one to go with? i dont plan on anyother performance mods other then what i posted maybe water meth but most likey not
Old 06-03-2009, 11:39 AM
lvmknsmoke..'s Avatar
guys have done it. just watch your boost and keep the adr turned off. lol id say u need a high tech 62 or 64. or some kind of 62 or 64 turbo.
Old 06-03-2009, 12:01 PM
STAGE 3.5 - 400 hp UPGRADE COMPRESSOR HOUSING AND 60mm High Flow WHEEL - 99-02 DODGE/CUMMINS
http://www.htturbo.com/cu.htm
how about this?
Old 06-03-2009, 01:30 PM
DIESELWRKS's Avatar
a HTT 62/14 would go good with this. I love mine. talk to Rip at sourceautomotive.biz great guy to discuss turbo talk. talk to more people before you buy one. but make sure you get one that you will out grow or cannot grow with you. and yes you need to up grade your clutch. with what I have I can still slip my clutch easily but thats mostly the smarty coming in early and hitting hard.
Old 06-04-2009, 01:24 PM
So in order to use the injectors I paid 500 bucks for, I have to spend another 1,200-1,500 dollars Thats Just Dandi , any one want a set of mach 4s lol
Old 06-04-2009, 05:41 PM
Pinkston's Avatar
PM sent on your mach 4s.
Old 06-04-2009, 06:32 PM
scottsjeeprolet's Avatar
I have a fellow chapter member running a Comp, HX40 and Mach 4's no problem.
Old 06-08-2009, 10:40 PM
What would be the best set of injectors to run with my Stock Turbo and the adr ? This is my daily driver , im trying to keep it smooth and driveable . Thanks for the help keep it coming!
Old 06-08-2009, 11:37 PM
Fern's Avatar
ADR will need an ugraded lift pump as would those injectors. VP44 no likey low pressure.
Old 06-09-2009, 12:12 AM
Fishin2Deep4U's Avatar
I ran a stock turbo with M4's and a Drag Comp fopr a while. You can do it, but as stated, a turbo will be required if you plan on putting you foot in it.
With that fueling. I would skip the hybid. You are gonna be at 500HP+ with that setup.
Dave
Old 06-09-2009, 07:06 AM
Old 06-09-2009, 07:22 AM
98whitelightnin's Avatar
I would go with some 75-100hp injectors. Im in the same boat, I have 150's, comp and stock turbo but im gonna put my 75hp sticks back in and see how it runs.
bruce03
12-30-2008 08:32 AM
NoSparkplugs
06-20-2007 08:19 AM
shoffs30
08-24-2005 10:46 AM
96_12V
07-07-2005 11:26 PM
Quick Reply: will this combo work?
