Color wire for backup lights?
Old 12-28-2006, 10:12 PM
ajg617's Avatar
Does anyone know the color of the hot wire to the backup lights in the harness out of the steering column? I want to add some halogen backup lights and need to tap into that wire. 2001 quad cab
Thanks,
Ajg
Old 12-28-2006, 10:23 PM
BIGROD's Avatar
I just tapped the hot wire at the bulb. Mounted a relay on the frame and ran a fused hot wire from the battery to the relay.
This was the easiest was I could see to do this. I used the cheap off road light relay.
Hope this helps Rodney
Old 12-29-2006, 07:07 AM
93w250's Avatar
If you have the rv connector just tap into that. That's how I did mine. I also use a relay. The back up wire in the trailer connector powers the relay, and the power for the lights comes from the aux wire from the trailer connector. Works great.
Old 12-29-2006, 08:06 AM
CRSmith's Avatar
I found a bolt that fit in the center terminal of the 7pin connector, which is the reverse circuit for a trailer. I wired to the bolt, and stuck the bolt in the terminal with a little dielectric grease. This saved me from having to splice wires. I have to unplug the backup lights when I tow, but it is not that often. Then of course, I had to ground the lights to something.
Old 12-29-2006, 06:16 PM
TIMMY22's Avatar
I did the same thing, I bolted the black rubber coated napa lights to the holes in my pintal plate. then, wired up a trailer connector plug just using the center pin. works great.
Old 12-30-2006, 08:54 PM
ajg617's Avatar
Thank all
What a clean solution. Thanks folks.
AJG
robert78.5
01-20-2008 10:18 PM
Syndicate
13
10-08-2006 10:30 PM
mt72916
02-01-2005 08:00 AM
99DodgeGuy
12-18-2004 10:08 AM
TPilaske
16
11-22-2002 08:15 PM
Quick Reply: Color wire for backup lights?
