codes
Old Oct 4, 2005 | 06:22 PM
Barefoot88's Avatar
codes
any body know what this code means i reset the apps by adjusting the voltage it threw a check engin light first code is 1693 compain code went to auto zone they said was a dodge code 1698 cant find it in the tech truck runs fine
Old Oct 4, 2005 | 06:59 PM
phox_mulder's Avatar
P1698 No CCD Messages Received From PCM
If I had to guess, I'd say a connection problem either at the PCM or the ECM.
phox
Old Oct 4, 2005 | 07:02 PM
Barefoot88's Avatar
phox
does this have to be cleared by dodge or will it go away in time
Old Oct 4, 2005 | 07:05 PM
Once you fix the problem, it should clear after X amount of engine starts with the problem no longer present.
X could be 10 or 50, depends on the severity of the code I think.
phox
Old Oct 4, 2005 | 07:17 PM
Barefoot88's Avatar
thanks phox for all the help think it done any harm
Old Oct 4, 2005 | 09:43 PM
MadDog01's Avatar
I have a friend who is a mech for the co I work for. He has all information on Dodge CTD's. The computers will erase codes after 40 warmups, if there are no other problems.
Gary
Old Oct 12, 2005 | 10:05 PM
ozarkcowboy's Avatar
01 codes
i got some codes i dont know what they are
p1693
p0341
p1690
p0230
if u can help id appretiate it
Old Oct 12, 2005 | 10:23 PM
Codes can be decoded at a couple of online places, this being one:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
This being another:
http://www.troublecodes.net/chrysler/96-01.shtml
P1693 DTC Detected In ECM Or PCM (companion code, the code telling you that the other computer (usually the ECM) has a code)
P0341 Camshaft Position Sensor Signal
P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor
P0230 Transfer pump Circuit Out Of Range
Sounds like you got yourself a dying Cam sensor.
phox
Old Oct 13, 2005 | 09:33 AM
thanx
thanx for the help, u know how much a cam sens. cost and if its somethin that doesnt have to go to a dealer?
Old Oct 13, 2005 | 11:58 AM
Here's a thread discussing just such an animal.
https://www.dieseltruckresource.com/...ad.php?t=80228
phox
Old Oct 13, 2005 | 12:09 PM
thanx
thanx phox
would that have nething to do with an unusual umount of oil comin out of the puke tube or is that somethin else?
cowboy
Old Oct 13, 2005 | 12:11 PM
thanx phox
cowboy
I'd say that would be something else.
Is your oil level fuller than normal? and if so, does it smell like Diesel?
phox
Old Oct 13, 2005 | 12:26 PM
nope
oil levels perfect and no fuel smell, i just got off the phone with cummins and they think the lift pumps goin out
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
