Codes
Old Sep 20, 2005 | 10:48 PM
BigBlue's Avatar
Codes
I pulled codes tonight and here's what I got:
P0622
P0743
P0500
P1492
P1765
I found the P0500 as being a vehicle speed sensor problem but my roommate just informed me that he got that after spinning his tires so who knows. But I can't find the other ones. Help me out guys. I'm gonna have the codes cleared before I get on the road tomorrow so I can see if they come back.
Old Sep 20, 2005 | 11:27 PM
CTD99's Avatar
P0622
P0743
P0500
P1492
P1765
From the FSM:
P0622 - Generator field not switching properly
P0743 - Torque Converter clutch solenoid / trans relay circuits
P0500 - No vehicle speed sensor signal
P1492 - Ambient / Batt temp sen volts too high
P1765 - Trans 12 volt relay control circuit
Hope that helps.
~ Russ
Old Sep 20, 2005 | 11:40 PM
BigBlue's Avatar
Ok. Two of them I can blame on the TC lock up switch (which is getting disabled after the DTT VB is installed). The others I have no clue. Battery temp sender? What in the heck is that?
Old Sep 20, 2005 | 11:47 PM
CTD99's Avatar
I recall something along the lines of a temp sensor in one or both of the battery trays... not sure what it does but just remember it potentially being an issue with optima batteries that use the "spacer" to make them fit better.
My guess is that if you have the codes erased, you won't see them again.
Old Sep 21, 2005 | 02:49 AM
Haulin_in_Dixie's Avatar
the battery temp sensor is under the left side battery. With optima's or any for that matter, unplug it, will never get a code. Makes little difference on the charge rate.
Old Sep 21, 2005 | 03:03 AM
Blue did you get the dreaded P911 code??
thats the hurricane sensor warning, makes the truck faster to get the h out.
Old Sep 21, 2005 | 10:01 AM
BigBlue's Avatar
Nah. I haven't gotten that one yet. I might later today though.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
