codes
I wish I could help you on the codes, I just checked the ones I have and I don't have a match to one of them. I have about 100 I think, well maybe not quite but none of the ones you mention.
P1693- not sure on that one, are you sure that is the code
P0720 Output speed sensor malfuction
P0122 Throttle position sensor (tps) / accelerator pedal position sensor (apps) signal voltage to low
That is what my repair manual has for you, but that first one is not in there are you sure it is correct?
p0122 is; throttle position sensor A circuit low
input
p1693 is; a companion DTC was set in both the ECM and PCM
none of the codes are serious, but will require attention soon
__________________
exwrestler
02-05-2010 09:34 AM
sallyman1
08-26-2008 06:20 PM
StormTrooper
03-28-2005 09:17 AM
