Codes codes and more codes Help!!!
The following codes keep coming up in my truck.
P0581
P0514
C1008
C2206
U0141
U0184
U0100
U0121
What is causing this and how do I fix it. I have had a mechanic clear these numerous times with no avail? please help
P0581
P0514
C1008
C2206
U0141
U0184
U0100
U0121
P0581 Low Voltage Detected At The Speed Control Switch
P0514 BAT Temperature Sensor Rationality
U0141 Lost Communication With Fcm (tipm)
U0121 Lost Communication With Anti-lock Brake Module
All I can find.
How are your batteries? I know the Can-Bus trucks are real sensitive to battery voltage. condition, and corrosion.
All I can find.
I am no expert but that looks like it could be a bad ground. The codes point to a power issue but if the batteries are good and the alternator was tested a bad ground would be what I would look for.
Hawkeye
04-17-2012 11:50 PM
798Lady
12-14-2010 11:48 AM
BIG85JEEP
09-13-2010 12:27 PM
sallyman1
08-26-2008 06:20 PM
