code reset
code reset
hi i have a code 713 tranny temp sensor voltage to high so i replaced the oil ,filter, tranny governor, and pressure reducer plus also blew out the tranny cooler just wondering if there is a way to reset with out a scanner so i no if i fixed the problem o ya were abouts is the tranny temp sender incase this didn,t work THANKS
Only way is a scanner. Unhooking the batteries ends up throwing an ECM power down code. And three key starts or after a few miles won't help if the problem still exists.
travelingman
10-26-2010 08:31 PM
NJMurvin
05-10-2004 06:00 PM
